Question about Galaxy Radios DX-55V Base CB Radio
Wandering off frequency
I own a galaxy 55v love the radio but i am having problems with it just slowly droping off to the 2400 band and then coming back up by its self i have replaced the voltage regulator checked for cold joints cant seem to find the problem even sent it out to a tech twice got a bag full of parts back that were replaced i guess, plugged it in and to no avail still wanders and when it drops down like that i can not key up the radio or receive either any suggestions would help thanks
  • 32 Answers
Man i love the galaxy radio! but when talking on ssb sometimes this becomes real annoying. Galaxy radios drift. They are my fav. brand of radio but i will admit they drift. and some times its real BAD other times its not too bad. i dont know how to solve it but SOME techs some real good ones who know galaxy inside and out can minimize the drift. im sorry i can not tell you how. look up protech cb shop try getting intouch with them, tell them your problem, and they should be able to fix it.
Posted on Jan 11, 2009
Can I reprogram my tk-2400 with my PC?
No. It is programmed from the Factory on a chip. Preprogrammed. No software will change it, no hacks. Many Motorola radios like that too. It is two watts, Vhf of Uhf, you did not say. If your existing frequencies are Business Band and in the same frequency band (Vhf or Uhf) you can get it to match those.
Oct 13, 2014 | Kenwood Radio Communications
Power decrease in my galaxy dx979
As you go up in frequency do the SWR (VSWR) go up or down? what frequency did the antenna get tuned at ?
Dec 18, 2012 | Galaxy Radios DX-979 CB Radio with Single...
On my radio I need the settings for the knobs because other people can hear me but I only get static and cannot hear them. Thanks
Band should be E Band high/low button on high 10 khz off AM selected
To check that you have done this correctly frequency counter will read 27.185 plus or minus 5 khz. This is of course proved you have a radio that is converted for 11 meter cb frequencies.
http://www.cbtricks.com/radios/galaxy/dx88hl/index.htm Frequency Conversion is the channel expansion mod/conversion
Sep 16, 2011 | Galaxy Radios DX- 88HL Base CB Radio
Frequency counter displays two digets high from hump on fine clarifier adjestment on usb.27.186 insted of 27.185. also in am mode shows dead on with clarifer hump until mic is keyed thin dropes from 27.185...
Turn that fine clarifier a 1/4 turn or so to the right. I own a Galaxy DX99V and sometimes if that clarifier is just right it will drop down a hundredth of a MHz just like that when the mic is keyed. Your radio is just fine. Just adjust that clarifier a tad. The Galaxy DX99V is one of the best radios out there. I love them. -73-
Mar 10, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
How to tune a galaxy 55v mobile to receive better
really the only thing you can do to the radio is make sure it is aligned, and that it is receiving on frequency. Although this unit has a frequency counter that will tell you where it's receiving, you cannot successfully put the radio on frequency unless you fully align the radio. In order to align a radio you need a volt meter, watt meter that reads avg watts, and an oscilloscope.
A volt meter and watt meter is easy to come by, however the oscilloscope is an expensive piece of equipment to attain.
You can just as easily tune your clarifier to the correct receiving frequency on the counter.
An easier way to improve your receive on any radio is to make sure the antenna is tuned for best SWR. When an antenna is tuned to the proper length for the best SWR your receive will get better because your antenna will be on Que.
There is also a Schottky diode upgrade that can be done. This consists of changing the detector diodes in the radio to schottky diodes as well as changing a transistor. This mod improves receive in most galaxy radio a great deal.
You can get these as a kit with full instructions on ebay fairly cheap.
You need to replace diodes D1, D2, D23, D24 with the schottky diodes in the kit, then replace TR-17, with the transistor that comes in the kit. Then remove TR-14. and them remove TR-19, and put the transistor from TR-14 in the TR-19 spot.
The Transitor that goes into TR-17 is a 2sc2999. I can't remeber what the Schottky part number is. But like I said, they sell the kits with complete instructions on ebay.
Here you will find all the technical information about your radio, as well as alignment guides.
Here is a link to ebay with an upgrade kit and instructions on ebay.
Oct 13, 2010 | Galaxy Radios DX-55V Base CB Radio
Galaxy 99 has same frequency 27.185 on am also on upper side and lower side band how come?? thank you
The frequency doesn't change when you change to USB or LSB. Basically the AM frequency takes up a certain amount of space, known as bandwidth, so it could fill in for example use 50 hertz above and below 27.185 giving 100 hertz bandwidth. When you use sidebands the am bandwidth is split in two so the upper side band would use the 50 hertz above 27.185 and the lower side band would use the 50 hertz below. The idea is that twice as many operators can operate without interference.
Sep 17, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
How do u adjust the frequency readout on a dx55v?
This radio has three modes, USB, LSB and AM. Each one has a voltage adjustment to center the frequency and they look like metal cans. You do need a analyzer to make this adjustment or at the very least a known frequency standard. Temperature can affect this display.
Feb 11, 2010 | Galaxy Radios DX-55V Base CB Radio
Galaxy Pluto frequency drifting
Find the crystals in the radio...hope you know what they look like...when you locate them touch one at a time to see if it will stop if it does you have a bad soilder joint on one of the legs or it could be that its time for a new crystal..they don't like the cold weather at all...but it is fixable so don't worry
Nov 27, 2009 | Radio Communications
Droped channel to 17 and frequency counter don't work?
sounds like a connection is coming loose inside. take it to a CB shop and see if they can spot it. Should be an easy fix, no more than 20 or 30 dollars
Jan 10, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Lost channels in a galaxy 66v cb radio
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
Aug 15, 2007 | Galaxy Radios DX-66V Base CB Radio
Galaxy Radios DX-55V Base CB Radio Logo
235 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Marvin
Marvin
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
