FixYa.com
Tags:
Onkyo DX-C380 6-Disc CD Changer
Carousel does not rotate from one cd to the next
posted by bblind on Jan 06, 2007
Plays first cd fine; however when it is time to rotate to the next cd it freezes up. Must then either turn on/off the cd player or open the tray and advance to the next cd in order to play.
Any advice?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 12, 2007
Not Rated (0)
theworld360
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I just had the same problem with my parents dx-c206.
I first found the motor drive unit with quite a bit of dismantlement, the drive circuitry is under the turntable as well for the drive motors. Once in the drive motor unit, the associated circuitry is clearly seperated on the circuit board between the drive and the actual cd spin motor and laser circuit, I checked all the voltages to common and all seemed fine, I then discharged the caps, and it then by itself started to spin again, it still has a few glitches, that it might freeze, could have been also a faulty cap. Real reason is unsure, this was a lucky fix... I did also remove what I presumed is a coil sensor unit that is also located under the turn table, once the small rectagular circuit board is removed u will find two U shaped (presumed magnetic sensors). I dought that any cleaning I did fixed this, but this could possibly have been infra red sensors, that would requirer some cleaning. These sensors are responsable for the turntable positioning.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these CD Players problems?
CD Players
philips cd player.
The product was purchase from... Answer This...
CD Players
CD player
I bought my player in the U.S.... Answer This...
CD Players
antenna for Phillips AZ1010...
Our boombox antenna broke off... Answer This...
CD Players
Samsung SCM-8300 CD Player
When putting CDs in, the system... Answer This...
Onkyo DX-C380 (6 disc CD)...
Ok, before I go ahead an junk... Answer This...
Repair Service
Find CD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
