Question about Philips 55P8241 55" Rear Projection Television
My 55 inch Toshiba Projection TV is getting fuzzy.
Is that an EZ fix and how. Or is it just going out? (I have checked the connections)
    Genius:
  • 2,920 Answers
Try to adjust the focus from the back inside the tv it may be out of whack because of the focus
Posted on Nov 26, 2008
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
Convergence
you must go to a repaircenter
some ic,s have to be replaced
Apr 07, 2010 | Toshiba 55HX70 55" Rear Projection...
My toshiba rear projection 55 inch tv is showing a double reflection in blue how do i fix it
Replacing the Convergence IC'S should fix it. They should be STK392-110's. I would replace both of them as a pair.
I hope this helps,
Skyassoc
Nov 14, 2009 | Toshiba 53H71 53 in. Rear Projection...
Fuzzy picture and dark picture and color seperation when hot.
The colors seperating is a convergence problem, as far as being dim this may be related but the TV likely needs service adjustments.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Toshiba TP55H60 55" Rear Projection...
52 inch Toshiba rear projection no picture has sound
You have bad solder connections in the deflection circuit. Call a good TV tech unless you know what you are doing. You could get an electrical shock from a charged capacitor.
Jul 06, 2009 | Toshiba 57H81 57" Rear Projection...
55" toshiba projection screen TV, front screen caveed in
get new ic's and replace them the kit is like $30 if you are good at soldering
Apr 03, 2009 | Toshiba TZ55V61 55" Rear Projection...
I want to download tv manuel for toshiba 55 inch
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000001850.pdf
You need Adobe Reader to read, but just load and click save = )
Feb 20, 2009 | Toshiba 55H70 55" Rear Projection...
CANNOT USE MY TV UNLESS CABLE BOX OR DVD PLYER IS ON
Your TV sounds like its signal board has went out and will need replaced (This is the most common cause of the problems you describe!)
Please rate response and help keep this site FREE!
Jan 03, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Toshiba 55 inch hdtv lamp
this is a crt type tv- no lamps just crt's if it was moved recently then a seal could have been damaged on the crt cuasing coolant to leak down the neck getting into the socket. this will cause trouble for sure also could have a crack in the crt. look for a sticky liquid in the bottom of the unit.
sometime the crt's can ark and rip out a video output chip on the crt socket check it out.
not common but not unheard of.cheers
Sep 26, 2008 | Toshiba 55H70 55" Rear Projection...
Tv screen is cracked
try www.tvscreenprotectors.com
they help with finding discontinued tv screens
Apr 29, 2008 | Toshiba TP55H60 55" Rear Projection...
Philips 55P8241 55" Rear Projection Television Logo
117 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
