Question about Cameras
My kodak digital camera won't turn on.
The camera uses 2AA which I recharge on my recharger. I have 4 batteries, 2 on recharger, 2 in the camera.. My camera won't turn on w/ any of my recharged batteries. Why?
  • Anonymous Dec 28, 2008
    my digital kodak camera c613 won't turn on
    President:
  • 2,712 Answers
First, remove the SD card (if there is one) and see if it works. If it does, then the SD card is damaged. If it still doesnt work, read on..
Try regular alkaline batteries. If they work, it could indicate that your rechargeable batteries are dead and need to be replaced, or there is a problem with the charger.
If the regular batteries dont work either, try cleaning the contacts in the battery compartment of your camera, or gently scratching the contacts with a jeweller's screwdriver. If it still does not work, there is an issue with the camera's power board and it will require servicing.
Posted on Nov 26, 2008
Will the battery recharge inside the camera while it is plugged into a power source?
Kodak EasyShare Z650 zoom digital cameraUser guide
Battery charging options Visit www.kodak.com/go/z650accessories for:
Kodak EasyShare camera dock series 3 - powers your camera, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak EasyShare printer dock series 3 - powers your camera, makes 4 x 6-in. (10 x 15 cm) prints with or without a computer, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak 3-volt AC adapter - powers your camera.
IMPORTANT: Do not use the AC adapter included with the Kodak EasyShare camera dock or printer dock to power your camera.
Mar 22, 2016 | Kodak EasyShare Z650 Digital Camera
I have just got a second hand cx4200 camera i have put in nomal batteries the light goes straight from green to red then switches off do i need kodak batteries
You can use any "AA" batteries, just make sure to use a fresh set.
Other options:
optional camera dock with Ni-MH rechargeable battery pack (in-camera charging); 2AA lithium or Ni-MH batteries or 1 CRV3 lithium battery, 3 volt adapter
Aug 19, 2012 | Kodak EasyShare CX4200 Digital Camera
Can i charge the camera away from the docking station ?
Yes, assuming you're using rechargeable batteries. If you're using rechargeable AA batteries, they can be recharged using any standard AA charger. If you're using the Kodak Rechargeable Battery Pack, it can be recharged using any of several Kodak chargers.
http://store.kodak.com/store/ekconsus/en_US/AddItemRefID/pageType.product/externalRefID.EKN031207#accessories
Jul 16, 2010 | Kodak EasyShare C533 Digital Camera
I have a new refurbished kodak easyshare c160 -- the camera will not last but for one or two pictures without completely draining the batteries. i have tried about 4 new sets of photo batteries....is this...
Solution: As digital cameras become more advanced and include more features, the power needed to keep them functioning has also increased. That means that typical alkaline batteries likely won’t do more than power your camera for a few shots before running out of juice. Sometimes, your digital camera may not power on at all if the inserted alkaline batteries aren’t fully charged or powerful enough. Rather than carry along dozens of alkaline batteries for a single photo shoot, you can save money by purchasing rechargeable NiMH (nickel-metal hydride) batteries. Rechargeable batteries can be purchased with a charger that you plug into a wall outlet, and they fully charge in one to five hours depending on the charger and the type of batteries you’re using.
If you’re already using rechargeable batteries but are experiencing short battery life with your digital camera, it’s likely time to replace your rechargeable batteries with new ones. Depending on the number of charging cycles you perform (how many times you discharge and recharge your batteries), rechargeable batteries typically last for two to three years before they no longer hold a full charge. You may also ensure that you’re charging your rechargeable batteries directly before use. As batteries sit unused for extended periods of time, they automatically lose some of their charge.
There are many ways you can conserve battery life while using your digital camera, too. For starters, if your camera has a viewfinder in addition to an LCD, use the viewfinder to frame your shots and turn the LCD off because LCDs draw a lot of power. If you prefer to use the LCD, you can still conserve battery life if you refrain from looking at each picture on the screen after you take it.
Jun 13, 2010 | Kodak EasyShare C160 Digital Camera
Won't use rechargeable batteries
It could be due to the fact that some rechargeable batteries are slightly different shapes and the nobbly bit on the + end doesn't reach far enough in, as it is the case with Maplin AA batteries.
In my case I placed a small drop of solder with a soldering iron on the + nipple and now they reach into any device.
Nov 26, 2009 | Kodak EasyShare C633 Digital Camera
My camera will not stay on is off and stuck with lens out
If the lens doesn't retract on most digital camera the camera also will not turn ON. It is connection or wiring between camera power and camera lens.
What Kodak Rep will ask you to do are:
1. Remove the battery and the memory card of the camera
2. Check if your using a recommended battery and if its new or fully charge. batteries for Z1275 are Ni-MH rechargeable; CRV3 Lithium; 2AA Lithium
3. Insert the batteries back in the camera in correctly
4. Set the camera in Auto mode (its the camera icon on the dialing mode of the camera)
5. Try to turn it ON
If still will not turn ON and the lens will not retract
6. If your using a rechargeable battery Kodak Rep will ask you to charge the battery until its fully charge.
If your using a disposable battery they will ask you to try to use a new battery out from the box.
After all those steps still the camera failed to work, it will be send for repair. The number of the Kodak support line is 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z1275 Digital Camera
Camera keeps going off even after I put in new batteries
1. Remove the batteries from the camera and then clean the battery contacts
2. Remove the memory card
3. Verify the batteries your using
Recomended batteries are
CRV3 lithium (non-rechargeable)
Ni-MH rechargeable digital camera batteries
2 AA lithium
4. Make sure to use a brand new batteries or fully charge batteries
5. inserted the battery correctly
6. Place the camera in Auto Mode [it's the green camera on the top of the camera beside the flash.]
7. Turn on the camera
**if issue was not resolved contact Kodak support line at 1 800 235 6325 (23KODAK) or visit the website www.kodak.com/go/stepbystep
Nov 16, 2009 | Kodak EasyShare Z650 Digital Camera
Batteries will not recharge on Kodak EasyShareDX4330 Camera dock seems to be working fine otherwise.
if your are using the ordinary AA rechargeable battery it will not charge., Camera dock will charge only on a 2 Pack AA battery like KAA2HR batteries or the 2 AA battery that attached together (Ni-MH rechargeable battery pack )
What type of battery are using?
try to purchased KAA2HR
Nov 05, 2009 | Kodak EasyShare DX4330 Digital Camera
Kodak easyshare Z740 battery problem
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Oct 22, 2009 | Kodak EasyShare Z740 Digital Camera
Camera keeps turning off
Digital cameras are very Voltage Sensitive. Using Nicad or NiMh batteries will not only , "Not" solve the problems above but will
actually aggravate the above problems for one reason.
Rechargable NiCad or NiMh batteries only produce 1.2 volts fully charged and will only give you 2.4 volts when used in pairs with this camera. This falls below the cameras desired 2.8 - 3.0 voltage requirement and will only result in about 30-40 pictures at most.
This camera requires a constant 2.8 - 3.2 volts to run properly. Kodak won't tell you this !!The camera was designed with Oxy Akaline batteries in mind.New alkalines will produce 3.2 to 3.4 volts in pairs but only for a short period of time.The issue with the Oxy Alkaline batteries is that they simply will not last very long in this camera due to its power requirements.
But there is a really great solution to the problem . You can purchase a CRV3 rechargeable Li-ion battery that fits right into this camera.
You will get a realistic 180-250 photos per charge.The Li-Ion battery maintains a constant 3.0 volts for a very long period of time
and will allow the camera to function the way Kodak originally intended it to and can be recharged. You will find rechargable CRV3 battery kits on ebay or other online battery stores at a very reasonable cost.
You can also use a Lithium Non rechargeable CRV3 battery that will give approx 250-300 photos per battery but you may
find non rechargeable Lithium batteries cost prohibitive.
I use the rechargeable Li-ION Battery exclusively in this camera and it functions perfectly since I switched. I have a pair
of CRV3 Li-Ion batteries so I always have a fully charge CRV3 ready to go.
For reference I was only able to get about 30 pictures with the high capacity 2800 Mah Rechargeable NiMH Batteries I used prior
to using the LI-ION Battery. I get on average about 175 pictures per full charge from the LI-ION Battery.
Jun 14, 2007 | Kodak EasyShare C875 Digital Camera
Cameras Logo
414 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
