Question about Toshiba Computers & Internet
Computer freezes up and clock stops
The computer freezes without warning and the clock stops and does not catch up to time. We replaced the hard drive and did a complete recovery but the problem still exists.
    President:
  • 2,712 Answers
You may have to replace the RAM modules and/or the CMOS battery.
Posted on Nov 26, 2008
Why is my Xbox 360 S freezing after 20 minutes?
This could be a case of the system over heating in which case you should have items removed from near your console.
You could also try removing the hard drive (make sure your Xbox is turned off before you remove it) and using your xbox without it, if that stops the freezing error then the problem lies in your hard drive.
(How to remove your xbox hard drive: https://www.youtube.com/watch?v=2NhALsgzR0M )
Jul 30, 2017 | The Video Game Consoles & Games
Emachine T 5212, when i turn it on,, a siren sounds,,then computer shuts off
In your computer (as well as other gadgets), the battery powers a chip called the Real Time Clock (RTC)chip. The RTC is essentially a quartz watch that runs all the time, whether or not the computer has power. The battery powers this clock. When the computer boots up, part of the process is to query the RTC to get the correct time and date. A little quartz clock like this might run for five to seven years off of a small battery. Then it is time to replace the battery.
This does not explain why your computer would not boot, however. You would expect the computer to boot fine but have an incorrect time and date. The reason your computer would not boot is because the RTC chip also contains 64 (or more) bytes of random access memory (RAM). The clock uses 10 bytes of this space, leaving 54 bytes for other purposes. The BIOS stores all sorts of information in the CMOS RAM area, like the number of floppy and hard disk drives, the hard disk drive type, etc. If the CMOS RAM loses power, the computer may not know anything about the hard disk configuration of your machine, and therefore it cannot boot.
Many more modern computers are not quite so dependent on the CMOS RAM. They store the settings innon-volatile RAM that works without any power at all. If the battery goes dead, the clock fails but the computer can still boot using the information in the non-volatile RAM area. I would change the battery and make sure unit is unplugged and my other hand is touching the metal frame on the computer to stop static discharge. Blow out the inside of the computer completely.Start computer with case off and make sure all the fans run and don't sound like a siren.Replace anything not running.It may not boot if the BIOS can't see the hard drives. You might have to start computer and watch the screen and when it asks you to hit a key to get into like the bios do it and see if you can reset it. If nothing seems be running right maybe the power supply went out they are real cheep at Tiger Direct.
Jan 24, 2013 | E-Machines eMachines Desktop PC
"operation system not fount" after pressing the start button
Turn it off. Symptoms suggest hard drive failure. Use of s taking a physical battering. This may damage data beyond recovery. The drive Take it to a shop. Your other choice: Oddly, freezing the hard drive sometimess temporaily fixes the drive long enough to recover data. Replacement of the hard drive is the likely fix. Unless you want to try to freeze the HD and copy data off of it quickly, only a shop specializing in data recovery might recover such. Hopefully youhave backed up data to another drive. You might want to consider a new laptop, after you eye the possible cost of repair and/or data recovery.
Jun 03, 2017 | Dell Studio Computers & Internet
Dell Vostro 1500 Laptop: Without any obvious warning, my laptop will no longer boot into windows vista beyond the "microsoft corporation" screen with the green progress bar. it will get past the...
@rkbrown1_rb
If your Dell diagnostics shows no fault on the hardware (hdd, memory, chipset, videocard, etc.) but still same issue occurs, I recommend doing another test using a different utility. Try using Hiren's Boot CD that can be found here and try running the S&M Stress Test 1.9.1 and Video Memory Stress Test 1.7.116. If your computer hangs while doing the stress tests, the video card or CPU might be failing already.
Good Luck.
Sep 05, 2011 | Dell Vostro 1500 Notebook
A message appears on my boot screen that a parameter has exceeded its range so i need to back up. My mouse alone freezes all the time
The message about parameters is from SMART monitoring, a function of the motherboard. SMART monitoring keeps a watch on several hard drive parameters, and warns you when they go out of preset limits. It's meant as an early warning that the drive may be failing, and you should back up any important data while you still can. The message doesn't mean that hard drive failure is imminent, but it's a good idea to do the backup if you haven't. It's probably also a good idea to buy a replacement hard drive now. They aren't expensive. Use a program like Norton Ghost to copy the current drive image to the new one, and you won't need to restore your system from scratch later.
Your mouse problem might be related to the disk drive, or it could just be a coincidence. A new mouse is cheap if the freezing keeps happening after you resolve the hard drive issue.
Jun 24, 2011 | Dell OptiPlex GX270 PC Desktop
Computer Freezes unless pressure applied
With the laptop turned off, take out the hard drive completely from the laptop and then reseat it back into its slot and make sure its nice and snug.
Then go ahead and turn it on and see it will run without freezing on you and having to apply pressure on the keyboard.
If that doesn't work then disconnect the keyboard and see if it will run smoothly without the keyboard. If it does then you might have a stuck key on the keyboard that is making the unit freeze so you might have to replace the keyboard.
Jul 06, 2009 | IBM ThinkPad T43 Notebook
Computer virus
You are doing well.i appears as though memory has failed.to run win xp you should need 512mb. of ram.After reinstalling the ram/memory reboot the computer.go online and go here and doownload dial-a-fix and run it.All should now be well. if not contact me here at FixYa.RICHARDM69 http://www.softpedia.com/progDownload/Dial-a-fix-Download-27328.html
Dec 09, 2008 | Intel i865PE (KD865PERLK) Motherboard
H/p desk top pc,xp exdition
If computer starts up all the way in safe mode, you have a better chance of salvaging this system.
If not, the hard drive may be crashed (physical damage, scraping oxide from the platters).
Worst case, you would have to replace hard drive and re-install windows and everything else.
Best case, a repair function can be done from a winXP CD that will replace windows files without erasing anything else.
If there is precious data on the hard drive, a data recovery may be in order.
I can provide a reliable and reasonable source for this service if needed.
Oct 25, 2008 | Computers & Internet
Computer freezing
The shutting down as well as the freezing issue could have been caused by any one or all of the hardware you replaced.......the trick is to change one thing at a time to help narrow it down
Assuming the Ram/HD/PS are new and ok I would look at overheating problems.... is the computer dusty ...look at the Heatsink on the CPU is it clogged with dust and are all the fans working ......use an Air compressor or a can of air from a computer shop to blow the dust out....
Another reason could be a Virus or spyware/malware ....run a full Antivirus/Spyware check ........
Jun 02, 2008 | Computers & Internet
Computers & Internet Logo
239 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
