Question about Maytag 30 in. Admiral LGC1330 Gas Cooktop
Cant find pilot or maqnual
Didnt have manual in box
  • Swilin Sampson
    Swilin Sampson May 11, 2010
    Can you give me the exact make and model please?
    Sergeant:
    Champion:
  • 291 Answers
Contact whirlpool to get a manual but be sure to give them the model number to get the correct one / whirlpool owns maytag now ,,,,,,,,,, you can even contact a sears service company to order one since the do the maytag service.
Posted on Nov 26, 2008
Two of gas burners will not light
Assuming you have electronic ignition on your stovetop, you may have spilled food onto the burner which has clogged the holes needed to get gas to the spark ignitor. Clean the holes (or slits) and dry them and try again. If they are not dirty, check to make sure you have a spark at each burner. If you have manual pilots, there could be many other problems, like the pilot is not lit, dirty vertical holes (on the burner side) at the pilot tunnel or tunnel is not positioned properly.
Mar 16, 2015 | Cooktops
Cda gas hob Pilot light not sparking to light hob, can use a match to light burners no problem.
IS THE POWER TO THE HOB ON ?
IF SO IS THE FUSE OK ?
IS THE PLUG WIRED CORRECTLY ?
TRY THESE FIRST, IF NO JOY YOU CAN DOWNLOAD YOUR PRODUCT GUIDE FROM CDA ON LINE
Dec 27, 2013 | CDA 4X4SS Cooktop
Where is the Pilot for my whirlpool oven
If you have a pilot light, it's in the oven section you take the bottom plate off with the 2 screws holding it on. It's going to be in the back by the burner valves. Most whirlpools don't carry pilot lights.
Nov 28, 2013 | Whirlpool Stove / Oven / Range Pilot...
I can not start the oven. The gas is on and the cooktop is fine.
The oven either has a pilot light to be lit before the oven will work or you need to light the burner each time you use it. Check your owner's manual or find the owner's manual on line and read it!
Dec 26, 2012 | Cooktops
My GE glass cooktop has a red light that goes on when in use (not theburner indicator light but a general light as soon as you turn one of the knobs. For some reason, today it is dimly on--even though...
I assume you are talking about general pilot light which illuminates when you turn any of the four hotplates on. This light gets its power supply from the hotplate contollers. The controllers generally have a pilot light circuit which links all 4 controllers to the pilot light. I haven't seen this problem before. Either a small amount of power is escaping across the pilot light contacts inside the controller or the pilot light is getting a feedback from another source/fault in the cooktop. The only solution is to dismantle the cooktop and use a voltmeter or similar to trace the fault. Unless you understand how the problem occurs it's probably best to call a repairman.
Feb 11, 2011 | GE Cooktops
PILOT LIGHT OUT. sTOVETOP CONTINOUSLY MAKES A CLICKING SOUND. i BELIEVE THE PILOT IS OUT. hOW DO i REIGNITE THE PILOT AND MAKE THE CLICKING STOP
Sorry to read about your problem, I hope this helps you out.
Their is no pilot lite on your oven..the clicking you hear is the electronic pilot system..
you have a defective control knob...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | GE Cooktops
Pilot on middle front burner does not light because it is not getting gas. I've cleaned the pilot gas port, but to no avail.
Hi, try following the pilot tube back away from the burner. You should be able to see a small screw used to adjust the pilot gas to that burner alone.Sounds like it is almost shut off. Turn it CCw to open it and set the how high you want it if this is a standing pilot.You should get the gas flow you need. I'm sure this is the problem. Best of Luck,
Shastalaker7
Dec 08, 2009 | Cooktops
Pilot lights
unplug the unit if the pilot ligth is electric.then u can use manualy.
Nov 19, 2008 | Cooktops
Maytag 30 in. Admiral LGC1330 Gas Cooktop Logo
124 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
