Question about Nvidia GeForce FX 5200 Video Card, 128MB DDR, TV-Out, 8X AGP, GEFORCE FX 5200 128MB 64-BIT Graphic Card
Video Problem I just started having a problem with my video card, the screen goes black momentarily.sometimes once, sometimes repeatedly for several seconds at a time. I've removed and reinstalled but no difference.Happens only occationally. Any Thoughts? Uneek
  • 100 Answers
Please give us your specs including the Monitor.
Posted on Apr 06, 2007
Just did the most recent update on my ps3 and now all I have is a black screen. I have restarted several times and the main screen will momentarily flash but then goes to black.
This may work. When the system is off press and hold the power button you will hear a beep keep holding you hear another beep then release the power button. That will reset the video settings which should return your picture ..
If not call 800-345-SONY
They may have other steps to correct the problem
Mar 13, 2011 | Sony Playstation 3 (PS3) Console
When I turn my monitor on, the screen shows the desktop momentarily and then goes black. If I turn it off and on a couple more times, the desktop will stay on and function normally. Where is the likely...
Try the monitor on another computer, to check-out the monitor.
Does the POWER lamp on the monitor stay on when the monitor goes black? If so, then the monitor probably is OK.
Try a different monitor, to trouble-shoot the video-card.
May 28, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Inspiron Core i5 Laptop. Error: Display driver stopped responding
Hi there!
You mentioned that's a 2 month old laptop,
From what i'm seeing here you should at least have 1 year of warranty with it if you purchased it online,
For the issue you have there,
Might want to specify what video card you have there.
For the drivers, go to support.dell.com then enter your service tag, make sure your select the right operating system, then you'll be able to see the drivers, update the video card driver and the BIOS,
If the problem persist go to nvidia and check your video card if they have released a new driver update,
Worst case scenario is replacing the video card.
Hope this helps!
May 27, 2010 | Dell Computers & Internet
Video displays momentarily when monitor is first turned on, then screen goes black. Problem repeats when monitor is turned off and then back on.
Check our web site at: www.ccl-la.com We have step by step repair guides for each of the versions of the E173FP monitor.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 23, 2009 | Dell E173FP 17" LCD Monitor
Funky screen on Toshiba A200 laptop
Either its a failing video card or failing LCD and in either case it will be several hundred dollars just for the part.
Most non-gaming laptops have integrated video built-in to the motherboard.
If you have never taken apart a laptop I would strongly recommend against it as you will be dealing with about 80 screws, parts that are taped, glued, clipped together.
If you do decide to the manufacturers generally have a how to guide and taking apart their laptops.
For my own benefit when I repair laptops I lay out sever pieces of paper and label them like back of laptop, front, under keyboard, ect to keep track of screws since size does matter :) when it comes to the screws.
Hope this helps
Nov 01, 2009 | Toshiba Satellite A200-0ET00X Notebook
Sometimes the screen goes black and will not work
the video/graphics you opened is too high where the video card of your unit cant handle it which turns into overdrive. upgrade your video card if necessary
Oct 10, 2009 | Sony DVP-FX810 Portable DVD Player
Monitor comes on momentarily then black...tried 2nd monitor same
I suggest you try another video card in your computer. This may be the culprit if the second monitor did the same thing as the first. If the different video card does the same thing, I would then suspect the motherboard.
May 31, 2009 | Samsung SyncMaster 931BF LCD Monitor
Screen is Black/Not on from start.
Try going into your BIOS by starting the notebook and tapping F10, when the screen comes up then tap once on F9, and choose to save default settings, and tap F10 again and exit. One other thing you can try is to connect your notebook to another screen or another PC so that you can see it is your video card or your screen. If you are having problems with your video card it will not show up on an external screen either, but if its your screen then you should be able to get video on another screen. If you do not get a screen in the BIOS screen then I would go to Radio Shack and have your video card tested.
May 31, 2009 | HP Pavilion dv1000 Notebook
Power but no picture
Try to re-solder the inverter part of the board. You may recognize that part where the 4 connectors from the backlight tubes can be found.... usually the small transformators (sorry, my technical English is not good) have bad soldering eyes after longer use. This may work if backlight turns on for a few seconds, then the power led is still alight but screen goes dark.... the inverter then "thinks" one of the tubes might be defective and turns power off. Hope this helps a little...
Jun 20, 2008 | BenQ FP71E 17" LCD Monitor
Nvidia GeForce FX 5200 Video Card, 128MB DDR, TV-Out, 8X AGP, GEFORCE FX 5200 128MB 64-BIT Graphic Card Logo
160 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
