Question about Kenmore 62872 Electric Dryer
Putting dryer belt back on
My belt fell off and i'm trying to put it back on however all i see is something with a wheel on it but I can't figure out how to secure the actuall belt...any ideas?
  • juther Dec 12, 2008
    I too have looked at this page and it does address this problem. The dryer is only showing one wheel. This diagram distinctly shows two wheels.
    President:
  • 2,992 Answers
The piece you see is called the idler pulley. Here's a link to a good description of how to change a dryer belt. It should show you what you need to do set it all right.
http://repair2000.com/wpoolbelt.htm
Posted on Nov 26, 2008
2 Suggested Answers
onthejob5130
  • 640 Answers
SOURCE: my belt fell off and
thats the idler wheel..put booth sides of belt coming of drum between that idler bracket the on the motor pully..onthejob
Posted on Feb 05, 2009
New samsung steam dryer stoped turning after i turned it by hand and herd a noise like something fell off in side
THAT IS YOUR BELT,, IF YOU PULL THE UNIT OUT AND UNPLUG IT, YOU SHOULD BE ABLE TO TAKE THE LITTLE PANEL ON THE BACK WHERE THE VENT COMES OUT OFF,, JUST LOOK IN AND YOU CAN SEE THE BELT AND THE PULLY I HAVE PUT SLIPPED BELTS BACK ON LIKE THIS BEFORE IT IS EASIER THAN TAKING THE TOP AND THE FRONT OFF
Jan 21, 2011 | Samsung Dryers
Cannot put the drum belt on
make sure the bracket is properly cliped to the base and the iderl wheel is twords the tub
pull the bel together under the tub, take the loop, pull it under the pully, lift the pully slighltly, place the loop on the motor
Oct 14, 2009 | Kenmore 74602 Gas Dryer
How to replace the belt for a whirlpool ler5620kq1 dryer
It is a very tricky task to put this belt on but I think I can work you through it. When you get the belt around the drum and get to the idler, push the belt under the idler wheel and through the forks of the idler pully assy. attaching it to the pully on the motor. Tension should be on the idler pushing the wheel up toward the drum. Hope this helps.
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
Can't remove motor from Whirlpool dryer (LER3624EQ1)
no set screw,,,put the motor back,,,put the motor clip back on...lock it back down...ok now take a wrench and put it on the end of the motor where the belt goes,,if your by your sef,,prop the wrench againt the inner cabnit wall,,,than turn the blower wheel its hard but it will come off you..just lock that motor shaft down,,grip pliers..wracket,,,please use glovers to turn blower wheel..housing is very sharp..onthejob
Jan 24, 2009 | Whirlpool LER4634J Electric Dryer
Can't Put Belt On
You have to remove the front of the dryer to
access the drum. First unplug the dryer.There are screws at the bottom of the front to remove the lower section. Once you remove that you can get to the screws for the door section. The front of the drum rides on the inside of the front panel so when you remove the panel the drum will drop down. Try to keep the drum in place with something to hold it up. Remove the old belt and place the new belt around the drum. Slid the belt back to where the belt used to ride and then loop the belt around the motor and the tension wheel. Make sure the tension wheel is tightening the belt. Hold up the drum and put the front panel back on. You may need a helper to hold things while you do this. Rotate the drum by hand and make sure it moves smoothly. Plug it back in and give it a try. I hope this helps. Any questions feel free to ask. Please rate me so I know if I'm Helping. Thanks.
Dec 30, 2008 | Frigidaire FEQ1442ES Electric Dryer
My belt fell off and im trying to put it back on however all I see is something with a wheel and I can't figure out how to secure the belt.... any ideas?
Nov 26, 2008 | Kenmore 62872 Electric Dryer
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
Nov 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
Putting dryer back together
from front with belt around drum ..gather slack and push under idler and around motor pulley right to left...recommend doing it before reinstalling front place rollers on front panel under front lip of drum and lift ..easier than trying to reach under front panel and will a little more slck in belt
Sep 13, 2008 | Kenmore 63012 Electric Dryer
Zanussi TC7114W condenser Drier
belts do not figure 8
they look something like this
f6516ed.jpg the front panel comes off, to access the drum without removing bearings etc, and the belt can be placed easily, around the drum and motor pulley.
then pull the tensioner hard against its spring, loop the belt around the tensioner and allow the spring to tension the belt.
Feb 14, 2008 | Zanussi TC7114W Electric Dryer
Kenmore 62872 Electric Dryer Logo
70 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
