Question about Kenmore 62872 Electric Dryer
My belt fell off and im trying to put it back on however all I see is something with a wheel and I can't figure out how to secure the belt.... any ideas?
  • 640 Answers
Thats the idler wheel..put booth sides of belt coming of drum between that idler bracket the on the motor pully..onthejob
Posted on Feb 05, 2009
Im not sure how to secure the back wheels. There is a small red rubber piece that was already attached to the rod, which i had to take off to put the wheel on and i put that on again after i put the wheel...
  • No, that is the piece. It is a lock washer of sorts. If it seems like it is a little loose this is because when these are pried off to access the wheel them little teeth inside the end cap get pushed in and don't hold like new. You can try taking a little screw driver and prying between them teeth to make it hold better but you may have to get a new one. The other option you have is you can epoxy it on and let it cure over night and that will hold.
Regards, Tony
Apr 30, 2011 | Toys
Need belt diagram for a 1986 Ford Ranger
should be one under the hood or get it at Autozone from a Chilton manual
Sep 24, 2009 | 2004 Ford F150
I removed the tilt steering colum housing to instal a new cruise
The plastic piece goes between the steel rod and cruise/wiper lever. You will have to remove the wheel and the upper bearing housing to get it back where it goes. If you put some wheel bearing grease on it then it will stay in place during reassembly.. Good Luck
May 15, 2009 | 1986 Chevrolet El Camino
1992 Toyota Paseo - Power Steering Belt comes off after install
i had the same problem the thing is that in the base of the A/C compressor the screw had a washer on both sides i remove them and problem solve ;-)
forgive me if i misspelled something i am from Puerto Rico ;)
Feb 03, 2009 | 1992 Toyota Paseo
Can't Put Belt On
You have to remove the front of the dryer to
access the drum. First unplug the dryer.There are screws at the bottom of the front to remove the lower section. Once you remove that you can get to the screws for the door section. The front of the drum rides on the inside of the front panel so when you remove the panel the drum will drop down. Try to keep the drum in place with something to hold it up. Remove the old belt and place the new belt around the drum. Slid the belt back to where the belt used to ride and then loop the belt around the motor and the tension wheel. Make sure the tension wheel is tightening the belt. Hold up the drum and put the front panel back on. You may need a helper to hold things while you do this. Rotate the drum by hand and make sure it moves smoothly. Plug it back in and give it a try. I hope this helps. Any questions feel free to ask. Please rate me so I know if I'm Helping. Thanks.
Dec 30, 2008 | Frigidaire FEQ1442ES Electric Dryer
Putting dryer belt back on
The piece you see is called the idler pulley. Here's a link to a good description of how to change a dryer belt. It should show you what you need to do set it all right.
http://repair2000.com/wpoolbelt.htm
Nov 26, 2008 | Kenmore 62872 Electric Dryer
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
Nov 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
2006 toyota camry serpentine belt
Hello if it came off someting is wrong!!! if it broke /snaped okay but if it fell off you might need to look into further repair!
Jul 28, 2008 | 2006 Toyota Camry
Power steering
have u put the car on the rack yet??? up in the air....then get somebody in the car, start the car, turn the wheel back-fourth...if no rack, just put it on jack stands, and try turning the wheel, but b safe.....and smart...so is the belt tight? is a line off going 2 the steering box?? could one of the lines b plugged?? dirt in it...while in the air, c if u can loosen one of the lines going 2 the box, 2 c if the fluid is going thou, just go A,B,C, check one thing at a time..later
Jul 20, 2008 | 1992 Toyota Celica
Hi....Need Help please....
Put the belt on the brush roll, place it in the nozzle, make sure the belt is in the center, turn the big knob on the front until it locks, then install the nozzle on the vac., turn the knob in the other direction, and it will be put on the pulley.
May 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kenmore 62872 Electric Dryer Logo
52 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
