Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Projection TV The screen has blue all over it, changed the bulb in the front no help
Changed bulb, but cannot get blue" change bulb and reset hour meter "banner off tv
You need to use the remote control that cam e with the TV and press the PIP/SWAP button on the remote and the VOLUME down on the front of the TV simultaneously for more than 10 seconds. Once successful the on screen display will tell you the lamp timer is reset to 0.
Sep 08, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Blue lines on screen...
Try Encompass Parts 1-800-638-3328
Dec 14, 2009 | Televison & Video
I have a mitsubishi vs-50605 in rear projection tv.i wand to know how to get to the bulbs to clean them? i also want to know how to change the blue convergence?
You have to remove the front screen or back panel. Every set is different.
convergence is in the menu - if you have the original remote.
Sep 04, 2009 | Televison & Video
My philips 50" projection tv screen looks green or light blue
the picture tubes are liquid cooled,coolant is contaminated and mist be changed.any questions just give us a call 410-388-9399
Sep 01, 2009 | Philips 60P8341 60" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Lightning Problem
I HAVE A 61" RCA INFOCUS ALL THE LIGHTS IN FRONT OF THE TV IS BLUE YOU UN PLUG IT AND PLUG IT BACK IN IT STAYS BLUE. YOU CANT TURN IT OFFOR ON
Apr 14, 2008 | RCA HD61THW263 61" Rear Projection HDTV
WD-52725
if you get a blue screen than your lamp is working fine. blue screen is considered "video mute" it display that blue if the tv thinks there is no video. try to reset the tv by pressing - menu 123 then reset to system defaults.
Feb 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
TV Image not bright enough
leagreen
I'm not sure if my answer will help much, but it is free. My experieence with this site is that without paying for premium service, you won't get much help.
I had a similar problem with a different model Panasonic projection set.I got no answer on this site, but I did from an outside repairman.
Turn your color all the way down. If it looks black and white it is probably not a bulb problem. If you see a tint (blue, green, red) over the screen, it probably is a weak bulb.
The entire bottom front of my model was held on by velco and could be pulled off.
Behind this was a removable black panel. Behind this were adjustment screws for the three bulbs. This will probably only help temporarily if the bulbs continue to weaken, but it might buy you some time as the replacement bulbs are quite expensive. Good Luck
Oct 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
