Question about MSI K8MM-V Motherboard
Blinking Power LED ... no other action
I received a replacement motherboard from MSI itself this board dosent start at all ... only the Power LED (Green Light in the front) keeps blinking ... i have tried removing / replacing all the following connections : - CPU - Front Panel Jumpers - Front Panel USB Jumpers - Power / HDD Connections Any solutions ???
  • Chintan Nanavati Jan 08, 2007
    tomj23
    thx for the info ... i have already tried all the steps mentioned above ...
    the board i m referring 2 is a replacement given by MSI service center itself !
    this is cause my board had developed a problem of restarting every 5 mins ... donno y
    this board i have tried all the steps mentioned above in 3 separate places !! still there is no sign of life in it .. guess i was just handed a dead board :(
  • 624 Answers
Hi switchblade, Some of this will seem basic or even a rehash of what you?ve already done but please keep an open mind. The one thing I?ve learned over the years is never assume anything especially when things aren?t working like they?re supposed to. -The first thing I would do is to check each screw, card, connector and component you installed to make sure nothings being shorted out or is improperly connected. Common occurrences are screws touching capacitor or other component leads. -Check the power connectors to make sure everything is connected correctly and that all the contacts are still mounted in the plastic connector correctly. -Check the output on your power supply and verify it?s rated for your motherboard. It?s possible that whatever caused them to replace the motherboard could have been caused by a defective power supply or vice versa. -Make sure the motherboard is correctly grounded to the chassis per your instructions. Typically the mounting screws touch a grounding plane on the motherboard and in turn ground that to the chassis. If your using plastic mounting studs that might be a problem. -Verify the power switch is working correctly. -Make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. -Try a more basic known good video card, a PCI if you have one. -Again whatever problem caused MSI to warranty replace your motherboard could have damaged your processor or memory. I would have expected a beep code but if you?ve gotten this far without resolving your problem we?re running out of possibilities. -If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
Posted on Jan 08, 2007
How to connect power switch,led,reset switch to MSI MS 7071 Motherboard?
They connect to the JFP1 connectors on the lower right edge of the board. The power LED connects to the 2 and 4 pins, The HDD LED to the 1 and 4 pins, the reset to the 5 and 7 pins and the power switch to the 6 and 8 pins. The pins are numbered up down right to left like this.
97531
08642
Aug 03, 2014 | MSI Computers & Internet
Tip
How to connect power switch,led,reset switch to MSI MS 7548 (aspen) Motherboard...
MSI doesn't have information on the 7548, since it was made directly for HP. Here is a diagram of another MSI similiar and usually they have their pins on their jumpers pretty much the same. You would use JFP1, And Pin's 1&3 would be the hard drive, 2 & 4 would be the LED, 6 & 8 would be the power switch, and 5&7 would be the reset switch. I know your motherboard is setup slightly differnent, but your JFP1 should be in the right hand corner all by itself.
I'm attaching a diagram of the layout of a similiar board
Good Luck Everyone!!
on Apr 02, 2010 | Computers & Internet
Power supply LED (Green) turned to red and blinking and nothing works
Power Supply is bad. Plain and Simple. Replace it. Regards, joecoolvette
Aug 31, 2012 | MSI Hp Compaq Evo Ms-6541 Rev 1.0...
All LED lights up but nothing comes out of the monitor and the LED for HDD is not blinking.
Make sure if you have a 4 pin 12 volt connector on the board, it is making connection to the supply.
Try disconnecting the power to motherboard from supply and disconnect your CMOS battery.
Short the clear CMOS connections to assure memory drain.
Remove and reseat your CPU and Memory.
Re-install all remove and try the unit.
Nov 25, 2009 | MSI K8NGM-V Motherboard
Power switch,reset switch,power led connections to motherboard?
Hi ramjet007;
This is strange because MSI doesn't have information on the 7548, since it was made directly for HP. Here is a diagram of another MSI similiar and usually they have their pins on their jumpers pretty much the same. You would use JFP1, And Pin's 1&3 would be the hard drive, 2 & 4 would be the LED, 6 & 8 would be the power switch, and 5&7 would be the reset switch. I know your motherboard is setup differnently, but your JFP1 should be in the right hand corner all by itself.
Front Panel Connectors: JFP1 & JFP2
Good Luck and don't forget to leave a rating.
Thanks Mark
Apr 25, 2009 | Computers & Internet
MSI 745 Ultra onboard power led
As far as I can tell, from the motherboard manual, there is no power on LED display on the motherboard itself.
Why do you think the motherboard may be blown? Maybe we can fix this problem...?
Aug 19, 2008 | Computers & Internet
MS-6378 ver 2 Motherboard fitted to my Time Computer
here it is your manual man
http://asia.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=283
msi site your board/the manual..youll have there at the beginning the diagram of wires and pins..
I have a MSI too..great boards man..great boards..
fixya:)
bye
Feb 07, 2008 | MSI MS-6378 Motherboard
MSI KT3 Ultra2-R Motherboard
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=497
Sep 26, 2007 | MSI KT3 Ultra2-R Motherboard
MSI K8MM-V Motherboard Logo
626 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
