Question about Magic Chef CYG2000AWW Gas Dryer
My dryer stopped working. A technician told me that the motor is damaged. I want to order a new motor but can't find a site with this motor, the price and how much it would cost to ship it to my island Aruba. I have a Magic Chef Dryer, model cyg2000aww. It has another problem too. The timer knob will not move by itself so it stays at one cycle. Maybe this caused the motor to burn. Si I need the switch too I think
  • 98 Answers
Try ebay.
Posted on Nov 26, 2008
Turn table stops turning, then motor shuts off
George A Faria,
I understand that the turntable stops turning and then the motor shuts off. I also see that you're stating the appliance works fine without the belt on it. My suggestion would be not to run the dryer without the belt. This can cause wear on the motor itself. What I would suggest is to put the belt back on. If it still stops turning and the motor is shutting off, I suggest contacting either the manufacturer or a local authorized technician. This way the root of the issue will be found and your dryer will last longer.
-Best Regards-
Jan 15, 2014 | Frigidaire GLEQ2152ES Electric Dryer
After fitting a new time to a hotpoint CDT00
Sometimes even one connection can make the circuit non functionable and so it can be due to a wrong connection. I request that you check once again and logically check the lines to go in order to start the cycle, INLET, cut off from the water level sensor, Start motor, stop and drain, spin and rinse, fill water and then for final dry and drain pump.
Check for all leads to be correct, check if the stepper motor works in circuit to move forward after the main power is switched.
Check this link for tips: washing machine
Jul 02, 2012 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
Dryer runs approx 10 min then stops
Sorry for the trouble but it sounds like you have a bad motor. I would recommend a qualified service technician come look at it and replace the motor they can be tricky a new motor will run you $125-$150 and whatever the tech charges for labor. If this is a older machine I would recommend you buying a quality used one or a new one I hope this helps and thank you for using Fixya!
Jan 26, 2011 | Roper Dryers
I have the heavy duty 4 cycle Amana dryer. When I turn it on it is very loud and stops after about 20 minutes. It smells really hot so maybe it's overheating? But why?
sounds like motor bearings are failing. causes motor to overheat and cut out on motor protector. I'm afraid a new motor is in order.
Jun 15, 2010 | Amana DLE330RAW Electric Dryer
Trying to replace timer 8299771. Can't find my
On the new timer , you have 2 wires comming of the timer motor . The blue wire should go to one of these terminals on the timer itself . The place where there is ONLY a timer motor wire going to , is where it should go .
Sep 04, 2009 | Dryers
Dryer heats for a bit then stops.
Looking in the wrong place. i see this 3 to 4 times a week. you have a bad motor. Motor will continue to run if the gas does not light. Just like it runs on air only. The motor stops due to internal switch that keeps it from catching on fire. Sorry someone put you on the wrong track but you will need to replace the motor.
Please rate this solution if helpful.
Aug 25, 2009 | Kenmore Dryers
Spin Dryer doesn't work on Hoover 500M
Most probably the solonoid (also called brake motor). This is a 5 rpm motor that activates the drum to spin. I just replaced it two days back in my machine (Model 500M0AUS - you'll have to be specific when ordering or better take the old one to the spare part shop) which had a similar problem. The new soloniod I bought had a shorter cable length so I had to improvised when fitting. If soloniod is the problem then make wure the steel brake lever tooth fits perfectly in axle groove when you finish replaceing it. Do the replacement when the machine has fully stopped after completing its wash cycle.
Repair technician quoted 250 while the solonid costed me only 86. I did not charge labour to myself:)
Hope this is helpful.
May 28, 2009 | Hoover Nextra HNT 2135 Top Load Washer
I have a Whirlpool model LER5636EQO Dryer which stopped working
check the belt, the drum rollers also take the belt off and check the motor
Apr 08, 2009 | Dryers
MAYTAG PERFORMA PYET244AYW
It could very well be a thermostat problem, however, it could also be the drive motor itself starting to burn out. Some dryers are equipped with a "Thermal Limiter" that will cut the power to heat. It doesn't seem to be the case for you. I would defiantely look into another thermostat but if it comes down to the motor, depending on the price, You may want to buy a new dryer.
Apr 01, 2008 | Maytag PYE2300AY Electric Dryer
Magic Chef CYG2000AWW Gas Dryer Logo
133 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
