Question about SanDisk Sansa m230 MP3 Player
Want to save recordings off M230 to my computer, how do i do that
How do i take voice recordings off my San Disk Sansa m230 and store them on my computer so that i can reformat the player
Go to play music then at the very bottom go to recordings.
open it then leave menu pressed till it says delete and go to the check if you want to delete or go to the x if you change your mind
Posted on Nov 30, 2008
SanDisk Sansa M230 Problem:When connected to my PC and try to open system says " this device is not formatted. Do you want to format it now?" . If "yes" is selected then system says it...
Connect your SanDisk Sansa M230 to your computer again. Ignore the format message and go to My computer icon on your computer, right click on the drive (E:or F: or G: etc) representing your SanDisk Sansa M230, scroll to format allow it format from there.
If it still refuses to format, you can the reset the SanDisk Sansa M230and try again.
In case you don't know how to reset your SanDisk Sansa M230, read the info on the below link on how to reset your SanDisk Sansa M23;
http://www.fixya.com/support/r6977146-reset_different_models_version_san_disk
I hope this helps.
Good luck.
Feb 22, 2011 | SanDisk Sansa m230 MP3 Player
How to delete music from sanDisk M230
>if you have the data cable means connect it with the computer
>Then go to the My computer and there you can find a removable drive it might be with the name of san disk
>opened that drive and you can find the music folder over there and from there you can remove the music files
............All the best
Nov 19, 2009 | SanDisk Sansa m230 MP3 Player
Erase everything from my Sandisk M230
Hello!
Im affraid to answer this question. because i only gain' thanks for trying" but its ok.
In your case , If you want to delete all files in your sansa, maybe you can delete it by formatting your sansa disk. You can find maybe the format on the menu and select format the disk(something like that.) Or you can connect the sansa to the computer and delete all files in there. You can browse your files in the my computer and select the drive created by computer when the sansa is connected.
may this help, melnavz
Mar 06, 2008 | SanDisk Sansa e200 MP3 Player
Cannot see m230 songs from My Computer
Check your WMP configuration, so that it will display Mp3 files
Oct 16, 2007 | SanDisk Sansa m230 MP3 Player
MWP does not recognize my san disk m230
i suggest an update software ,this will solve the problem.
May 31, 2007 | SanDisk Sansa m230 MP3 Player
I need help with my mp3 it wont let me listen and i already tried to format it and it did not work. it still says not enough space for music db please free 8 MB. and then it says no files and my computer...
Your M230 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M230 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M230 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Computer Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Computer Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M230. The lower section also contains the drive # pertaining to your M230. Right-click on either drive letters pertaining to the M230 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M230 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this file to your Desktop and run it while your M230 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M230 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M230 is a great player
Apr 15, 2007 | SanDisk Sansa m230 MP3 Player
San Disk Sansa m 230 512 MB
Your problem is probably beacause you accidently deleted "AudibleActivation.sys" from your "Audible"-folder. Format the sansa and then use "reset to factory settings" to make the file appear again. It might be a good idea to make a backup on your hard drive, just in case, and make the file hidden.
Oct 31, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
