Whirlpool duet washer model ghw9400pl1
Little metal ring fell out when I opened the door and I found that the rubber gasket had come loose and got wrapped up in the laundry. The tub seems to have a lot of play fron to rear like some springs or something that hods it in place have come loose and being held by one mount on top.
-   I have a whirpool duet washing machine. The front of the gasket has become a bit misshapen. Today the spring tightened metal ring was loose and I found 4 socks trapped inside the area typically blocked off by the rubber gasket. I re fit the metal ring but there still seems to be a bit of play. the gasket is tight at the top but very loose and ill-fiting at the bottom. I'm running it again to see if it will leak. help?
-   silvachr
if your metal ring (clamp) came off it is most likely due to you shocks or the spring at the top are worn out and need to be replaced. this will happen more often if the cycles are off balance or the washer is over loaded
Was this helpful?
Yes
No
Popular Solutions for Whirlpool GHW9400 Front Load
My whirlpool duet started flashing the FH error code after running for one minute (filling with...
(More)
My whirlpool duet started flashing the FH error code after running for one minute (filling with water hot, cold or warm). I hit the pause button and restarted sometimes it runs the first time or after several tries. I ran the diagnostic test got the fh code at C:01 the first time I ran the test. I reset the washer and restarted it worked well. I cleaned the drain pump filter got a baby sock, 76cents and five pens. Any idea why I still get the fh code sometimes.
Our washing machine shows 06 code. Sometimes fills up with water, even when not in use. When...
(More)
Our washing machine shows 06 code. Sometimes fills up with water, even when not in use. When unplugged for a while sometimes it works, other times fills up with water, won't drain or spin.
