Question about Sungale PD708 Portable DVD Player with Screen
Sungale pd708 portable dvd player
When we insert dvd it tells us there is no disc. we have used this before without problems, and this just started yesterday. we have tried several dvd's with the same result.
Your DVD lens needs to be changed.this can be done by a qualified techn.But before taking it to a techn.try inserting a lens cleaner.to see if that will corect the problem.
Posted on Jan 27, 2007
SOURCE:
Wrong disc
this problem is normally a fault due to using a dvd disc that is not from your country region. check the dvd box and make sure the region code matches your country that you a veiwing it in.
Jul 12, 2010 | Sungale DVD-2026 DVD Player
My portable dvd player is telling me "no disc"
the problem is from you laser lens, the lens is weak that's why its telling you "no disc". The lens is weak such that it cannot load/disc.
Use a lens cleaner to clean the lens and if it does not solve the problem, then it means you will need to replace the player lens to solve the problem once and for all.
Good luck.
May 10, 2010 | Zenith DVP615 Portable DVD Player
When you put a dvd in it it says no disc I used all dvds it tells me the same thing the player is about 2 years old
try to use cd cleaner first. usually len has a dirt thats why you player was unable to read year disc. if same thing happened after you cleaned the lens. then it might be a lens problem
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 25, 2010 | Durabrand PDV-709
Dvd not playing
2008 EXCHANGE MODELSNO PARTS FOR SERVICE
Aug 20, 2009 | Polaroid PDX-0073S Portable DVD Player
Philips PET710 DVD player shows 'no disc' when disc inserted
I have the same problem with my portable dvd player and found that cleaning the lens of the player using a non-alcolhol wet nap for cleaning eye glasses worked well. I also found the rail that the optics runs along while playing needed a very small amount of silicone greese applied using a Q-tip. You may find that the optic unit may be "stuck" somewhat but can be resolved by gently moving the optic along its guide using a finger.
This changed my unit from not working at all, to working intermittantly sometimes having to vary the player on and off to recongnise the disc. Hope this works
Jul 28, 2009 | Philips PET710 Portable DVD Player
Sungale portable dvd model number pd580
I need a battery for a Sungale DVD player Model Number PD580 how can I get one.
Apr 28, 2008 | Televison & Video
Panasonic Portable DVD Player LS50
Can you see or hear that the disk is spinning up normally as it did before? I understand that the small, spin-motors on these portables often go bad.
Jun 06, 2007 | Panasonic DVD-LS50 Portable DVD Player
Keeps saying loading but never shows picture
take your set to tech the lens need to be adjust or the strip is getting in the way.
Feb 19, 2007 | Sungale PD708 Portable DVD Player with...
Sungale PD708 Portable DVD Player with Screen Logo
110 people viewed this question
Top Sungale Televison & Video Experts
janman
Argospete
Argospete
Are you a Sungale Televison and Video Expert? Answer questions, earn points and help others
