Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Freezer is defrosting and keeps buzzing on and off. I assume it is the defroster kicking in. This seems to happen when I buy groceries. I have Thanksgiving dinner in my freezer (a lot of money there) and it is thawed. I need to find out how to disable the defroster or re-set it. I have tried to turning the freezer off for an hour, I have moved it several feet from the wall and removed half the items inside. I don't know if somehow I am blocking a vent when I load the groceries and it is causing this, but when I removed half the groceries I made a point to make sure nothing was touching the back walls where the vents are, and there is ample space around every shelf. I also, emptied the ice tray. The unit was cleaned last time this happened. I have in the past been able to remove everything and unplugged it for several hours and corrected the problem. But I can't afford to do that this time.
  • 2 more comments
  • christyfalli Nov 26, 2008
    This unit has a computer, a defrost thermostat connected to an adaptive defrost unit. I have concluded that is is an issue with the adaptive defrost, although I haven't pulled my fridge out to see if the coils have froze up, I will be doing that in a bit. I think it has something to do with the defrost unit. The diagram says to press the fresh food switch 5 times in 6 secs to activate the defrost and then do the same to deactivate it. That didnt help. From the diagram ("which I am rather illiterate in reading") it appears the adaptive defrost module and thermostat are above the top shelf near the freezer. So I will avoid putting things on that shelf in the future.....
    So I am resorting to defrosting the entire thing and will see tomorrow if it will return to normal. Which has worked on the past occasions this has happened. If not I will call a repairman to check the thing out I hope I don't have to buy a new fridge this close to xmas....
    The unit is a FRS26HF6BW1 Frigidaire 26 cu ft side by side Refridgerator with filtered ice/water.
  • christyfalli Nov 28, 2008
    I let the Fridge completely defrost and started her back up and is back working fine.
  • christyfalli Apr 28, 2009
    well, this thing has been such a pain. had the service guy come out guess what it was working when he plugged it up stupid freaking thing. so it lasted until now and is doing it again. I had 2 come out they both say replace the compressor. ( I think they see poor girl and easy money! ) But that doesn't make sense to me as it eventually seems to start back up at sometime or another after ruining all my food of course
    I think that it is the PTC Starter. Does anyone know if this might sound correct?
    I checked the relay that plugs into it and it looks ok not burned no shake noise. (I don't have a volt meter and wouldn't have a clue how to use it if I did) I am worried about taking the ptc out myself. It's jammed in there with tons of copper tubing around it that I am afraid to damage. I tried just pulling on it like the relay but it didn't budge. I can't see any screws and according to the replacement parts it plugs into "pins" on the compressor. Can I pull it off without damaging the compressor? Does anyone know if it has screws. The part number is 218721119. Any suggestions on removal please... Also, I plan to replace both the PTC and relay. Any helpful information you might suggest is welcomed greatly!
    I was also told it could be the defrost thermostat or thermostat. Anyone else dealt with this? I love this fridge and don't want to have to buy another... help a poor girl out!
  • 311 Answers
Buzzing noise is bad compressor. Tries to start and can't so it trips the overload. Compressor may be under wty- call Frigidaire to see.
Posted on Nov 28, 2008
Freezer works, fridge does not. The coils in the freezer wear iced over. Unplugged, thawed, turned defrost timer switch til it clicked. Plugged back in. Freezer still getting cold. Assuming defrost timer...
The defrost timer for a model FRS26ZSG is found behind the kick plate at the bottom and front of your refrigerator. You will need to pull the kick plate off. If you turned the timer then that is the defrost timer part number=> 215846602 Defrost Timer I am here should you have questions, Sea Breeze
Jul 30, 2013 | Frigidaire FRS26ZSG
Our refrigerator keeps shutting off, about once per day but at different intervals it seems. If we don't notice, it will defrost, melting freezer contents into a puddle on the floor. If we do notice, we...
If this model has a mechanical cold control (one with a knob) then I suspect it is shutting off at temp but not coming back on when it should . Try tapping the control with the handle of a butter knife gently while off . If it immediately starts then I would replace the control.
Feb 27, 2011 | Whirlpool ED2FHSS Side by Side...
Not recovering
Make sure the fan in the freezer is running circulating the air.
How to check everything
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 03, 2009 | Freezers
HELP!!! Frigidaire 26cu ft sxs compressor buzzes on & off? PTC?
When a compressor won't start and “clicks,” this indicates it (the compressor) is locked up and cannot start so it clicks off on an overload thermal (temperature) protector. If the compressor only runs for a short time then clicks off it is likely drawing too much amperage, overheating and cutting off on the overload protector. Nothing other than replacement can be done with a compressor that is locked up or drawing too much amperage as it is a problem with the internal components of the compressor.
It is absolutely crucial that the condenser coils are clean and the condenser fan motor, if there is one, operates properly or the compressor will overheat and go off on the overload protector. This handy <a href="">condenser brush</a> makes cleaning your refrigerator condenser coils a snap.
The compressor can be replaced but this is very expensive ($400- $500 parts & labor) due to the fact that the refrigerant needs to be reclaimed from the system and the compressor refrigerant lines unsoldered, new lines soldered on and new refrigerant charged into the system. This is something only a trained and licensed repair person can do. Compressors are part of the "sealed refrigerant system", many manufacturers warranty the components of this system for an extended period of time, usually 5 years from the purchase date.
appliance parts, help & more
Apr 28, 2009 | Frigidaire FRS26H5AS Side by Side...
GE Profile Fridge/Freezer defrosting
You will need to replace the electronic mother board which is located in the back of the refrigerator,Inside rectangular cover near the bottom left.
Feb 28, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Zanussi ZX99/5SI
you have a fault in the defrost system - possibly due to a faulty module
Jul 14, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
282 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
