Question about Panasonic CF30 Notebook
My cf30 rubberized keyboard functions but will not backlight. Is it malfunctioning or is there an option somewhere to activate it/turn it on?
There is a function key combination that turns on the back light, I believe it is Fn+F12. Hod down the FN key and press F12. The first press turns the backlight on full brightness and succesive presses dim it until it is turned off.
I'm sorry but I don't have my CF-30 in fromt of me at this time, it could be Fn+F10. There is a blue symbol on the correct key and I believe it looks like a light bulb.
If this doesn't work, you may need to have a hotkey driver installed.
Posted on Apr 19, 2009
How can I get my keyboard light to come on?
The key just to the right of the space bar is the backlight key. Pressing the backlight key scrolls through the backlight levels of OFF - LOW - MEDIUM - HIGH.
Hold down the backlight key and press the right or left arrow keys to scroll through the colors.(WHITE, RED, AMBER, GREEN, AQUA, BLUE, VIOLET).
However, when the battery is at 20% or less the backlight feature is disabled to conserve the remaining battery charge.
Jul 06, 2014 | ZAGG Folio Keyboard
How to activate malfunction keyboard of Letter D?
If both the upper and lower case don't work you have a keyboard problem. If one works you need a print wheel.
DickyO
Oct 23, 2013 | Brother GX-6750 Typewriter
I am not able to work with my keyboard function keys and num keys and function keys . but the the touch pad key is onlyworking .please send a solution to unlock the keyboard. hp pavilion g6-2102tx
Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon. Hope this helps.
Dec 10, 2012 | Computers & Internet
How do i turn on the keyboard backlight on my toshiba satellite p200-1fc laptop?
Hi registrat342,Look on your keyboard & there should be 2 pictures that look like a sun on your function keys and 1 that is next to those but it has eyelashes and a box under it. Every keyboard might differ-but hopefully you get my point-as in 3 total 1st=dimmer, 2nd=brighter & 3rd would be the backlight. With mine-all I do is click it. Yours might be a little different. Hope that helps. Sherry
Apr 11, 2012 | Toshiba Satellite Computers & Internet
How do i turn my kepboard light on?
Set the brightness of the backlighting
1. In the device options, click Screen/Keyboard.
2. Set the Backlight Brightness field.
3. Press the Menu key.
4. Click Save.
Set how long backlighting remains on
2. Set the Backlight Timeout field.
4. Click Save.
Stop backlighting from dimming automatically
2. Change the Automatically Dim Backlight field to Off.
4. Click Save.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 17, 2010 | RIM BlackBerry Pearl 8100
Explaination of icons on G73 keyboard
I assume you mean the function keys. Here they are:
F1 - SleepF2 - Toggle WiFiF3 - Keyboard backlight dimmerF4 - Keyboard backlight brighterF5 - Screen DimmerF6 - Screen BrighterF7 - Turn off displayF8 - Enable external displayF9 - Toggle touchpadF10 - MuteF11 - Volume downF12 - Volume up
Hope that helps!
Oct 01, 2010 | ASUS G73JHA2 Notebook
How do I turn the keyboard backlight on my laptop?
Hit Fn Key then F1 key
Toggle sequence: for the unit with backlit keyboard :
  • 1st toggle: All system LEDs on
  • 2nd toggle: Backlit Keyboard LEDs off, everything else on
  • 3rd toggle: Multimedia touch LEDs and control functions off, everything else on
  • 4th toggle: All system LEDs off and Multimedia control functions off
Jun 02, 2010 | Gateway NV5928u (LXWJH02001) PC Notebook
Keyboard backlight does not turn on for SGH-i617
it does sound like an short in the circuit somewhere could have been caused from something being spilled on it or being dropped, your lcd screen does not use the same one as your keyboard backlight, but check the settings by holding the cv button until the menu pops up if it dosent work then its probably broke hope this information was helpful:)
Nov 04, 2009 | Samsung BlackJack II Smartphone
Backlight does not light when receiving an email on the 8330
To turn on the automatic backlighting on a BlackBerry smartphone, complete the following steps:
  1. Click Options.
  2. Click Screen/Keyboard.
  3. Click Change Option in the Automatic Backlight field.
  4. Click On.
  5. Click Save from the Screen/Keyboard menu to turn on the automatic backlighting.
Aug 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How to activate wireless connection without FUNCTION key on lapto
The wireless button is required.there is no option in the softwares to turn on wireless.
Jul 06, 2009 | Computers & Internet
Panasonic CF30 Notebook Logo
717 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
