Question about Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor
Digital not working
I have a dell 1702fp monitor and i am using the correct DVI-D - DVI-D cable for digital input from my nvidia fx5950 ultra but i get no signal , however if i use a dvi TO rgb cable i DO get a picture , the dvi end being plugged into the fx card. any idea how to fix the digital side , also the self test does not work (no floating iamage when turned on without any cables plugged in)
  • 9,156 Answers
The latter part of this post seems to confirm that the problem is inside the monitor, probably a failure on the signal / video board. You might also look for damage to one of the connectors. Otherwise, if your manual shows some settings or a rest, that might be the issue. But the fact that the self-test does not work leads me to believe that the unit needs a new a signal / video board.
Posted on Jan 07, 2007
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
Acer monitor no signal
If your monitor has various input sources, make sure it's on the correct input source in the main/input menu. If that's not the problem double check the cable for bent pins also make sure if you have a video card with DUAL dvi outputs that your using the correct one.. as the other one might be secondary and non-functional. It's possible but highly unlikely if you unplugged the DVI cable while the monitored was still powered on it could have damaged the video card of the computer or mainboard of the LCD monitor. When in doubt try another DVI cable if all else fails.. if you have another DVI monitor (thats a known good) try that also to make sure that the video card is not the problem.
Nov 05, 2013 | Acer H243H Monitor
No signal ???????
I have the same problem in setting up two displays, a Dell as primary and a VA2223wm Viewsonic as secondary, both connected to an Nvidia geforce 9500 GT. I think it might be the cable, but it's baffling. I have one DVI cable that seems to work on either monitor, and either plug on the graphics card. The second DVI cable doesn't seem to work, but when it's connected to the Viewsonic, the Nvidia control panel detects the monitor as secondary, so I can change settings, etc., but the monitor still says no signal. Each monitor works separately when connected with one cable, but not with the other.
Thoughts?
Jul 23, 2013 | ViewSonic VA2223WM 22 inch Monitor
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
I cannot hear any sound from my Dell monitor 1702FP. Are there speakers installed within the monitor?. VGA cable is connected. When I use a spare monitor using the VGA cable the sound is loud and clear. ...
The Dell 1702FP doesn't have speakers.The specs of the Dell 1702FP are available here: http://support.dell.com/support/edocs/monitors/1702fp/en/specs.htm . (BTW neither does the Dell 1704FPT.) However, some Dell monitors can have a sound bar (speaker set-up) mounted on the monitor.
VGA cables don't carry sound. Check if a second cable (an audio patch cable is connected to the computer and the second monitor). (There are some cables that actually bundle the 3.5 mm patch cable with the video cable for convenience. (I've seen a number of DVI cables with that bundle option.) The plugs will separate into separate units at each end.
Other monitors do have speakers built in - look for a 3.5 mm audio input jack with the rest of the input connections on your monitor. There are some monitors that accept an HDMI input with a 3.5 mm audio out jack; these monitors don't have speakers and thus are enabling a daisy chain to connect the speakers to the monitor. So you do need to be careful and look for the audio in label.
You can attach a set of speakers to your computer using the audio out (look for a lime green 3.5 mm jack on the back of a desktop). For laptops or to use the front audio ports, look for a headphone jack.
I hope this helps. Please add a comment with more information about your monitor and computer for additional assistance.
Mar 11, 2012 | Computers & Internet
I have a nVidia Quadro2 MXR/EX video card which works fine on the analog input but when you use the digital input the screen sometimes flashed at startup and then goes blank. If you move the mouse,...
There are a few things that come to mind here. Number one is to try a different and known functioning DVI cable. Maybe see if you can recreate the problem simply by wiggling the dvi cable. If there are any splitters/adapters, remove them and plug the cable straight from the video card to the display. Make sure the display is set to digital input mode. When you are using the digital cable, make sure to completely remove the analog cable. See if this problem happens outside the operating system (such as in the system bios, if it does, this indicates a hardware issue). Finally, the digital input on the monitor could be having an issue, try a different monitor or try this monitor with digital input from another system.
Sep 24, 2011 | HP NVIDIA Quadro2 MXR (32 MB) AGP Graphic...
If you add a DVI adapter to the the DVI cable going to the Dell Inspiron 580 VGA input, do you get true DVI quality? Can you use a DVI to HDMI adpater?
For the best results, you a straight DVI cable.
VGA is analog, while DVI is digital. The quality will not be as good a a regular DVI cable.
You can use a DVI to HDMI.
I use one going from my PC to TV and the quality is awesome.
Mar 03, 2011 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Emerson 42 inch television flat screen HDTV: i connected a DVI to HDMI cable to dell computer screen to television in order to display computer screen to it but the signal isn't working, how do i...
Your Dell Monitor does not have a video output. The DVI/HDMI cable needs to run from the DVI-Out of you computer tower directly to the TVs HDMI input, ideally one with a red/white analog audio input next to it, because that cable only provides a video signal. If you don't have a DVI out on your computer, perhaps your TV has a VGA input. If your computer/video card only has one monitor connector, then you can only connect the Monitor OR the TV.
Dec 27, 2010 | Emerson Televison & Video
Dell228wfp on start up pwr on is green screen
Either the cable is not connected to the proper port or the display-source is not configured properly.Here's what you can try.
  • Ensure that you have connected the VGA/DVI cable in the correct port. If you have an extended graphics card in your computer, use a DVI cable(Digital input) else the VGA would be the only option available.
  • If the cable seems to be plugged at the right place, press the first button from the left on the front panel of your monitor (Button 1 shown in the front view: http://support.dell.com/support/edocs/monitors/E228WFP/En/ug/about.htm#Front_View), once. This toggles the digital mode to analog mode of your monitor, and vice versa.
  • If the first two steps do not work, its not an issue with the monitor. It could be a failing cable or a defective video card, or the system itself is not completing the POST.
Thanks,
Abhishek
Feb 06, 2010 | Dell E228WFP LCD Monitor
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor Logo
144 people viewed this question
Clive
Clive
Alun Cox
