Question about GE Profile PDW9880NSS Stainless Steel Dishwasher
I Hve a GE profile microwave model JVM192k 004. I know there are 2 mounting screws that are in the cabinate above it but where are the rest of the mounting screws. I have a new one I want to replace it with
  • 1,543 Answers
This is a little strange, but you have to take the grill off that goes all the way across the top front of the microwave. Now, use a slot blade screwdriver to unscrew the two metal rods that go from the front to the back mounting plate. )one on each side of the oven) Microwave should not swing forward and down, allowing you to lift the unit off the back wall mounting plate. Watch out for possible exhaust vent restricting movement of micro forward and down also.
Posted on Nov 26, 2008
Replace a fuse on GE Profile model jvm1871SH02
Unplug microwave or shut off house breaker. Remove grill or cover that goes across the top of door and control panel.Remove screw that holds control panel on and lift up on control panel. It will tilt downward and has 2 tabs at the bottom that go into slots. It can be lifted out of those slots.The fuse should be seen at the top area in the microwave behind where the control panel was mounted. Fuse is usually small 1/4 round type fuse like old type car fuses that were glass but the micro fuse will be either a white of gray ceramic fuse not glass. Some are 15 amp some are 20 amp. Usually stamped on end of fuse.
Mar 01, 2015 | GE Microwave Ovens
I have a GE Profile JVM192K convection microwave. I need a new 130v40w bulb for it.
The procedure and part number (WB02X4253) are on page 43 of your owner's manual.
If for some reason you don't have yours, you can download it here:
You can find helpful exploded views and order GE parts from the Pros here.
Apr 22, 2013 | Microwave Ovens
Remove mounted GE Spacemaker Microwave JVM140K
There should be 2-3 screws thru the floor of the cabinet above the m/w that secure it in the front. Once those are removed the m/w will slide straight out on rails mounted to the wall plate.
Dec 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Just wanted to know the size of the GE profile microwave model JVM1660BB005. Is it 1.5 cu ft? Looking at a new model JVM1540LNCS to replace it and want to use the same mounting hardware.
In GE microwaves, the first 2 digits of the model number are the cubic footage. 1660 is 1.6 cubic foot, 1540 is 1.5 cubic foot. Take care trying to use the existing hardware, the exact placement of hardware and upper installation screws may vary from year to year or model to model..
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Wall template mount for ge profile microwave
You can may be able to order that by looking up parts by your full model number here.
Jan 10, 2010 | GE Profile Over-the-Range Microwave
I have ge under cabinet microwave model jvm1331 004 that i need to remove. what holds the unit in place?
Look in the cabinet above the microwave. You should see a vent if it is vented outside. You will need to remove the vent. Then look in the same area to find two screws that will need to be removed. Disconnect the power cord and have someone hold the bottom of the unit and remove the screws. It will fall at this point so hold it good. With the screws out and vent removed you will be able to let the front of the microwave down a little. This will allow you to now lift the back to release it from the channel hook in rear. Then you will see the mount plate on the wall. It should have screws securing it to the wall on stud locations. remove these screws and remove the wall plate. Hope this helps. Good luck.
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
Installation of undercabinet microwave
If the OTR is the same model, the mounts should be the same. As long as you use the same bolts/screws from the old one, or the same length new bolts/screws, it should be a fairly simple exchange.
Mar 24, 2017 | GE JVM1440 Microwave Oven
Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Nov 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile PDW9880NSS Stainless Steel Dishwasher Logo
168 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
