Question about Hyundai ImageQuest ImageQuest Q770 17" CRT Monitor
REGULATOR I have a hyundai monitor Q770 and the regulator IPC 01 is damage and I don`t have a service manual for remplace it. Can you help me? Thanks
  • betochahin Nov 27, 2008
    I have a hyundai monitor Q770 and the regulator IPC 01 (it have 5 terminals) is damage and I don`t have a service manual for remplace it.
    Can you help me?
    Thanks
  • 348 Answers
The regulator ic is lm7812 series lm no matter replace it or 12v regulator
Posted on Nov 26, 2008
01 hyundai accent no code powerloss real slow to accelerrate,was doing a drive cycle for evap monitor reset.SMH
My friend is a part time mechanic he gets his solutions from www.reliable-store.com
he gets from their every single detailed info, instructions etc. on all vehicles, and manuals like service, repairs, parts, owner's, operations, maintenance etc.
U can get help from there
there is a girl at chat she can help you
Mar 20, 2018 | Hyundai Cars & Trucks
My battery light came on while i was driving than a few minutes later everything shut off. The battery was replaced in january and alternator was replaced in october.. what could be the problem?
For the alternator to work B+ voltage must be applied to the heavier gage wire on the back of the alternator ,plus the alternator is computer controlled , by the PCM !
Charging System Indicators
BATTERY The IPC illuminates the battery indicator when the following occurs:
The PCM detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the PCM requesting illumination.
The IPC determines that the system voltage is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the body control module (BCM) indicating the system voltage.
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
The ignition is on, with the engine off.
BATTERY NOT CHARGING The IPC illuminates the battery not charging indicator in the driver information center when the following occurs:
Your best is to have a qualified repair shop check it out ! Could have DTC'S - diagnostic trouble codes stored !
DTC P0562
The powertrain control module (PCM) continuously monitors that the system voltage stays within the proper range. If the PCM detects an excessively high system voltage, DTC P0563 will set. A high voltage condition may cause a stalling condition or other drive ability concerns.
DTC P0621
The powertrain control module (PCM) uses the generator turn on signal circuit to control the generator. A high side driver within the PCM allows the PCM to turn the generator ON and OFF. When Generator operation is desired, the PCM sends a 5 volt signal to the voltage regulator via the generator turn on signal circuit. This causes the voltage regulator to begin controlling the generator field circuit. Once the Generator is enabled by the PCM, the voltage regulator controls generator output independently of the PCM. Under certain operating conditions, the PCM can turn Off the generator by turning Off the 5 volt signal on the generator turn on signal circuit. The PCM has fault detection circuitry which monitors the state of the generator turn on signal circuit. If the fault detection circuit senses a voltage other than what is expected, this DTC will set. The voltage regulator also contains fault detection circuitry. If the regulator detects a problem, the regulator will ground the generator turn on signal circuit, pulling the voltage low. This also causes the PCM to set the DTC.
DTC P0622
Checking for codes an voltage drop testing the connections an using a scan tool to check data parameters is the only way to solve your problem . Which means taking to a qualified repair shop !
Jul 26, 2016 | 2002 GMC Envoy
99 Blazer V6 4x4 Intermittent start problem New battery Alternator? good Start a few times then won't, no sounds/lights Voltage read low Charge battery and it's good for a few days Any suggestions
When the vehicle is running check voltage at the battery . should be 13.1 to 14.1 volts , if not the alternator isn't charging . Doesn't matter if the alternator is new , has to have B+ voltage on the heavier wire connected to back of the alternator . The other wire connected to the alternator comes from the PCM/ECM . Is the Battery symbol light on when vehicle is running ?
The powertrain control module (PCM) or vehicle control module (VCM) turns the generator ON or OFF, by applying voltage to the generator control/monitoring circuit 225 (RED). The regulator in the generator also requests the charge indicator located in the instrument panel cluster (IPC), using the same circuit. When the regulator monitors that either a voltage high or voltage low condition exists with the engine running, a ground path to the PCM/VCM will be provided through the generator control/monitoring circuit 225. The PCM/VCM then sends a serial data message to the IPC requesting the charge indicator to be turned ON. The IPC monitors serial data messages from the PCM/VCM, and turns the charge indicator ON when requested. It mite be best if you take your vehicle to a qualified repair shop , unless you like making parts stores rich , buying unneeded parts .
May 18, 2016 | Cars & Trucks
No power on
Difficult to work out what was damaged.
47mF is a very large capacity; 47000uF!
Sep 20, 2017 | Hyundai L72S-8 17" LCD Monitor
Suddenly, I can see only a part of the display width. I can't control the width size in the screen setup (all the other functions are OK)
see that it may be from the resolutions..if you give it a smaller one ..and it is a wide screen format ...it will hae black 2 inches wide band on each side... just right click on desktop properties and settings ..and restore a normal resolution on it ..
Apr 25, 2010 | Hyundai ImageQuest ImageQuest Q770 17" CRT...
Sign of old age?
it is a problem with CRT screen.you can checked it from service center.
Dec 11, 2009 | Hyundai ImageQuest ImageQuest Q770 17" CRT...
Where is the transmission filter on a 2003 Hyundai elantra? Does it even have one? Does it look like an oil filter or like a pan?
Hello elisa 15miran: My name is Roger and I will answer your question for you. As per a Hyundai. repair manual. bulletin 01-40-007. There is no transmission filter that needs to be changed. The filter is inside the case and is not serviceable except for when overhaul of the transmission.
Should you need further help please just ask. Please rate the quality of your answer as this way we know you received the correct answer. Thank You for using Fix Ya. Roger
Jun 20, 2009 | Hyundai Motor 2003 Elantra
Help pls
A possibility is that the VIDEO selections you have made are too acute for the screen and Windows cannot continue (nor can it tell you it can't) so press F8 key while booting, select 'Last known Good' and see if that flies. Last known good is the settings for your PC that worked last time you booted. If that does the same thing, then reboot using F8 again and select 'Safe mode'
This will force WIN to use only known good settings, and then you can fix the problem by START, RUN and typing 'compmgmt.msc', choosing 'Devices', clicking the little + by Display Adapters, highlighting yours and hitting the DEL key. This will remove it and its settings from the Registry (but not the HD) and force Windows to reinstall and reconfigure it
Hope that all helps!
Cheers
Apr 08, 2009 | Hyundai ImageQuest ImageQuest Q770 17" CRT...
Resetting "service tire monitor" light on 2004 silverado
I have a 2004 Silverado with the same problem.
After scrollng the internet for months and reading every manual I could get my hands on, I found, for me, a quick and easy way. Open the hood, remove the cover to the Underhood Fuse Block on the drivers side of the vehicle near the battery.
If you have the manual for your truck, go to page 5-126 and locate the fuse that says IPC/DIC, it is a 10 amp fuse.
Pull the fuse and start your truck or a few sceonds.
You will notice that nothing on your insterment will work.
Turn engine off and replace fuse.
After I did this, the message did not come back, and started my truck about 15 times to make sure.
It worked for me....good luck to you.
Dec 05, 2008 | 2004 Chevrolet Silverado 3500
Hyundai ImageQuest ImageQuest Q770 17" CRT Monitor Logo
270 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
