When i try to boot my 470 xeon workstation with 2 cpu's I get three beeps and it won't boot.
    Sergeant:
    Champion:
  • 258 Answers
I think the memory is loose remove and reinsert the memory properly
Posted on Nov 26, 2008
  • 53 Answers
Check the memory ram, take all the ram out and try it one by one, also check the video card that its not loose and how many sticks of ram does it have?
Dell precision t3500 problem boot code light 1-2
Yes, you'll get that error message if SATA Operation (SATA Mode) is set incorrectly in BIOS setup.
Sep 26, 2014 | Dell Precision T3500 Computer Workstation...
Dell precision 470 work station processor fans over speed
Dell Support > Precision 470 Workstation Desktop PC > Users Guide,
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/index.htm
Tools to Help Solve Problems > Diagnostic Lights,
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/advtrbl.htm#wp1057482
"A possible VRM 0 has occurred"
VRM = Voltage Regulator Module
Here is what the motherboard looks like,
http://www.ebay.com/itm/DELL-PRECISION-Workstation-470-XC838-Motherboard-with-2GB-/140795014004?pt=Motherboards&hash=item20c8096b74
[Note* Posted for photo reference only. Not for advertising.
Besides, I do not see any VRM's plugged in. Means you get the motherboard only, and no VRM's. You need a VRM ]
What the Voltage Regulator Module looks like,
http://www.thebestpartinc.com/kg229.html
(Again, not for advertising. Click on the photo of the VRM to enlarge)
Notice that your motherboard has two VRM's. This is because there are two Processors.
Apparently the VRM for one of your Xeon processors is bad. (Z-on)
Since it states VRM -> 0, it is for the Processor 0, or in the number 1 processor socket.
What does a Voltage Regulator Module do for a Processor?
Regulates voltage.
A Processor MUST have a steady, 'clean' supply of voltage, AND it must be within the voltage range for the processor.
Since the motherboard uses an Intel E7525 motherboard chipset, it can support Intel Xeon processors, with up to an 800MegaHertz Front Side Bus. (800MHz FSB)
Looking at a typical Intel Xeon single-core processor, with an 800MHz FSB, let me show you it's voltage requirements,
1.287 to 1.400 (DC)
May be just a bad VRM.
However, I would also like you to look at the Electrolytic Capacitors on the motherboard. From what I have seen, those motherboards are notorious about having capacitors go bad.
Visual identification of bad Electrolytic Capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 09, 2012 | Dell Computers & Internet
I have a broken Dell Precision 470 Workstation. The symptoms are as follows: Won't power up; Flashing yellow power LED on front panel; Blank STR_LED on motherboard; Yellow AUX_PWR LED on motherboa
Flashing front powerlight is often a result of a faulty powersupply, try another powersully on the pc and see if the problem gets solved. I've seen a few of these cases personally.
Jul 01, 2012 | Dell Precision Workstation 470 (204816690)...
L would like to know how to reset bios setup
Good day,its only for load set-up default or,jumper at simos settings..tnx
Aug 17, 2011 | Dell Motherboard For Precision 470...
Dear sirs, I would like to upgrade the cpu`s of my Compaq Evo W6000 PC with the Motherboard Model 06D0h. Please let me know what are the strongest cpu`s I could use. Many thanks Murat
I suggest this to you.
Intel Xeon Processor, 1.4 GHz/100.0K
Intel Xeon Processor, 1.5 GHz/100.0K
Intel Xeon Processor, 1.7 GHz/100.0K
Intel Xeon Processor, 2.0 GHz/100.0K, L3
Intel Xeon Processor, 2.2 GHz
Intel Xeon Processor, 2.6 GHz/400
Processor, 1.8 GHz, 603FCPGA
Processor, 2.0 GHz, 603FCPGA
Processor, 2.2 GHz, 603FCPGA
Processor, PRST, 2.4 GHz/400, INT 261668-004 284645-001 source: ftp://ftp.compaq.com/pub/supportinformation/technotes/evo_w6000_workstation_rev6_us.pdf
Jun 29, 2011 | Compaq Evo Workstation W6000 PC Desktop
Boot failure, beeps and no display
Hi.
Do this solution first in the motherboard only processor installed need no memory.then power on your PC.if your motherboard no continues beeping.that need replacement of parts specially capacitor
leakage,became big or burn parts.
See beeping code.
Beep Code:
Description of Problem:
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep
Everything is normal and Computer POSTed fine
Two Beeps
POST/CMOS Error
One Long Beep, One Short Beep
Motherboard Problem
One Long Beep, Two Short Beeps
Video Problem
One Long Beep, Three Short Beeps
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
Continuous Hi-Lo Beeps
CPU Overheating
Jun 17, 2011 | Dell Motherboard For Precision 470...
Hello, When i start the computer its starts a
Oh geez, you have some work ahead of you.
I would somehow acquire another video card (ask a friend :)). Put that in and see if your computer boots up. If that still doesn't work its either the CPU, or the Motherboard.
I would take apart the heatsink, remove the CPU, reseat it and see if it works.
Let me know! ill help
May 19, 2011 | Dell Precision Workstation T5400 Quad Core...
My dell percision 470 is dead. Don't know if I need a new power supply or motherboard. Dave Moll
you can check the power supply by voltmeter if it works then may be mother board is dead
Aug 18, 2010 | Dell Motherboard For Precision 470...
I installed a e5430 xeon processor into an xw8400 workstation and now it does not want to boot up.
maybe your system needs a bios upgrade before it runs with the cpu... happened to me once too, although with a different system. Give it a shot.
Oct 06, 2009 | HP ProLiant ML350 G5 5U Rack Xeon QC E5430...
DELL PRECISION WORKSTATION 670
Have you tried a differnt video card?  Also disconnect everything including the hard drive to see if the system will POST.  If it does, them start connecting 1 item at a time.
Oct 25, 2007 | Dell Precision Workstation 670 PC Desktop
Computers & Internet Logo
David Payne
David Payne
