Question about Linksys Wireless-G Broadband Router
Finding a local area connection
When i start my computer it says that its status is aquiring network address, but then it says that the local area connection status is limited or no connectivity and that it is not able to access the internet or some network resources. Is there a universal address that can be assigned? I do not have the manual, or is it because of the rural area i live in?
    Scholar:
  • 70 Answers
Is this a wireless connection?
If yes than most of the times the problem is that the signal is weak, try to put your Router/AP to a better place and see if you can connect, netstumbler can give you a hand in this, not sure if it's working under vista or not, but under xp it's perfect. My experience ist that what you need to have at least is 15 For SNR for your Router from the place where you are trying to connect. If it goes under 10 it will drop you down.
Better SNR means stronger signal and that's all that matters with a simple wireless connection.
Regards
Imre
Posted on Nov 26, 2008
How can i get an ip address
Firstly, what operating system are you using?
applicable for windows xp or windows 7. press Windows Key + R
select the appropriate network connection (e.g. Local Area Connection). Right click the Local Area Connection choose Properties. For windows xp, doble click Internet Protocol. For Windows 7, double click Internet protocol IPv4. choose Obtain an IP address automatically. press OK. right click again the Local area connection then choose Status. there tou can see that your computer is negotiating for an IP address from the dhcp server. if still cannot obtain an ip address, press Windows key +Run then type "services.msc". scroll down and find DHCP client. ensure that this service is running.
Please also try to check if the network you are connected does have a DHCP server.
Jul 01, 2013 | HP Compaq nc6220 Notebook
I got a wrt54gh router just less than a year now. it is connected to our desktop being used by my son & grandson in our living room, while i'm using my laptop in my room. it just happened that i...
If you have Windows XP then try this, for Windows 7 and Vista also the procedure is similar. If you have Vista or 7 then tell me I'll post the tutorial for that also.
  1. In Windows XP, click the Start button and select Control Panel.
  2. Click the Network and Internet Connections category.
  3. Note: If you are using Classic View, you will see the control panel icons instead of categories. Double-click the Network Connections icon.
  4. Click the Network Connections control panel icon.
  5. Double-click Local Area Connection, listed under LAN or High-Speed Internet.
  6. When the Local Area Connection Status window is displayed, click the Properties button.
  7. In the Local Area Connection Properties window, do the following:
    • Verify that the Internet Protocol (TCP/IP) box is checked.
    • Note: If your Ethernet adapter is not listed in the Connect using box, you need to install your adapter.
    • Click Internet Protocol (TCP/IP) once to highlight it and then click the Properties button.
  8. In the Internet Protocol (TCP/IP) Properties window, do the following:
    • Click Obtain an IP address automatically.
    • Click Obtain DNS server address automatically.
Apr 11, 2011 | Linksys Wireless-G WRT54G Router
How to find ip address on a computer with windows vista?
There are two ways to find your IP address:
- Through the Network and Sharing Center
- Through the Command Prompt
How to find an IP address through the Network and Sharing Center:
1. From the Start Menu, right-click on Network and click Properties.
2. A Network and Sharing Center window will open. Click View status to the right of Local Area Connection.
3. In the new Local Area Connection Status window that opens, click Details. Your IP Address will be listed among the other connection details.
How to find an IP address through the Command Prompt:
1. From the Start Menu, type Command Prompt in the search field then click Command Prompt once it appears.
GL
Jan 02, 2011 | Computers & Internet
How come the http://192.168.123.254 address isnt working?
Find your computer's IP address : Windows 7, Vista, and XP, using the command prompt
  1. Click Start, and then select All Programs. Note: If this doesn't match what you see, refer to About navigation settings in Windows.
  2. Click Accessories, and then Command Prompt.
  3. At the command prompt, enter: ipconfig The IP address (or IPv4 address, if you are using Windows 7 or Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx (i.e., 156.56.27.32).
Note: If you are using PPP with a modem at home, your IP address will change each time you log in.
Windows 7, without using the command prompt
  1. In the system tray, click the network connection icon and select Open Network and Sharing Center.
  2. To view the IP address of a wired connection, click Local Area Connection. To view the IP address of a wireless adapter, click Wireless Network Connection (Network Name).
  3. Click Details... . Your IP address will appear next to "IPv4 Address".
Windows Vista, without using the command prompt
  1. From the Start menu, right-click Network, and then select Properties. This opens the Network and Sharing Center.
  2. To view the IP address of a wired connection, click View Status to the right of Local Area Connection. To view the IP address of a wireless adapter, click View Status to the right of Wireless Network Connection.
  3. Click Details... . Look for the address next to "IPv4 IP Address".
Windows XP, without using the command prompt
  1. From the Start menu, right-click My Network Places, and then click Properties.
  2. To view the IP address of a wired connection, double-click Local Area Connection. To view the IP address of a wireless adapter, double-click Wireless Network Connection.
  3. Click the Support tab, and then click Details... . The window that appears will display the IP address.
Your IP address has to be in the 192.168.123.xxx range
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range 192.168.123.100 through
192.168.123.199
• The default LAN IP address for the router is
192.168.123.254 with a subnet mask of
255.255.255.0
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 26, 2010 | Asante FriendlyNET FR1104-G Wireless...
Why can't I access the Url http://192.168.0.30
check your IP address and see if the computer you are using is on the same subnet. your IP must be 192.168.0.xx where xx is any number. if you get a different IP address, use a static IP address between 192.168.0.31 to 192.168.0.40
how to check IP:
click Start - Control Panel - Network Connections - right click Local Area Connections - click Status - Details.
how to use static IP:
click Start - Control Panel - Network Connections - right click Local Area Connections - click Status - Properties - TCP/IP - choose Static - use any IP address in the range above.
click apply and try to access your repeater again. I am assuming that you have given the correct IP of your repeater.
Apr 17, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Cannot access the URL addres http://192.168.0.30 (page cannot be displayed) any suggestions?
how to check IP:
I can not connect to the local area connection.
1. check your network adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 justcheck the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
hope this will help you
Nov 26, 2008 | NetGear WGR614 Wireless Router
IP Address
Or you can select START > then>CONTROL PANEL then>NETWORK CONNECTIONS then RIGHT CLICK LOCAL AREA CONNECTIONS and select STATUS
Nov 23, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Laptop can't aquire IP address
This sounds to be a compatibility issue with either the wireless software or wireless card. Check to see if there are any updated drivers for the wireless card at IBM's support site. If there aren't any or the card still doesn't work after the updated drivers are installed, then you might try a different/newer internal wireless card, or a universal external wireless card for use with your home system.
Jul 30, 2008 | IBM ThinkPad R51 Notebook
Linksys Wireless-G Broadband Router Logo
83 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
