Question about Zanussi FJS1225W Front Load Washer
Zanussi error e20 then ele
Hi there can anyone advise... have a zwf1217 w washingmachine.. it stoped mid cycle and i had to drain manually. e20 came up so i checked the filter , it was clear, took the pump out and checked outflow pippe , all clear reassembled and it still will not work although i may have put the two red pump wires on wrong an error of e23 comes up, i swapped the wires over and ive tried to start the cyle mid cycle at drain but it sits idle and then all the lights on the programes go out and it jumps to drain at bottom and comes up error e20 again, if i hold in the sart/pause and skip buttons it runs through all the light sequencesand shows up 8.00 at some places but all of a sudden it now shows up ele when i do this , the machince is only 10 months old , can you help regards frag
Somebody suggested to me that there is a condensation tray at the back that has become blocked. He said to take the back of the washing machine off and at the bottm right hand corner there is the condensation tray. This will need de-fluffing!! I haven't tried it yet but am also looking for answers!! Let me know if you come across any other info. Pete
Posted on Apr 17, 2007
Zanussi washer dryer showing e20 error message in dryig cycle
Hi
This means that the filter is clogged. Unscrew the filter it'll be full of lint. E20 also means drain problem. If it actually goes through the Spin cycle then there is most likely some water still not drained out at the time of the tumble dry. Check the drain and the hose to make sure it isn't clogged.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 03, 2011 | Zanussi Washing Machines
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
Error message on washing machine E20
E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
the drain pump may be blocked
or possible your filter is totally blocked. Clean out the filter everything will work again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there.
Good luck.Please rate the solution if accepted, also do post comments in case of any doubts.
Jan 23, 2009 | Zanussi Washing Machines
Drain pump removal on Zanussi FJR1254 Washing Machine
not easy.suggest you disconnect pump and power up independently as an easy way to check if it runs
easiest way to remove pump - and its awkward - is to undo the 3 screws holding the pump to its housing
Jun 29, 2008 | Zanussi F1245W Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
324 people viewed this question
Top Zanussi Washing Machines Experts
jimorris77
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
