Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Not receving fax
When receiving fax on my machine after two rings my machine reads receiving. The fax keeps ringing but nothing is coming through and there is no fax tone for the machine to receive a fax. The machine was working; all I did was change the ink and this problem started. Is there anyway you can look into this problem and let me know what to do? My cell phone# is 416-559-6252 and my fax# is 416-431-9663. This is a brother fax machine MFC-3420C.
Thank you for your urgent response in this matter,
Clairmont
  • 67 Answers
Is your fax set on AUTO REC mode? It sounds like it got tripped into MANUAL MODE for some reason.
Posted on Dec 02, 2008
The fax dosn't work,what should I do? I don't have ring tone, and can't receve.
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
May 14, 2012 | Brother MFC 240C All-In-One InkJet Printer
Fax not picking up Brother 4100
have you see the display if it was saying the word receiving...?
let me know..
Jun 26, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother all in printer, fax problem
Make sure you have a DSL Filter installed on the phone line to prevent DSL signals from interfering with the operation of the fax machine. A DSL filter looks like a line splitter or Y-Adapter and you should have received one or more of them with your DSL modem.
Jan 17, 2008 | Brother Multi-Function Center MFC-240C...
Not receiving faxes. Machine just keeps ringing.
Make sure fax is not set to TEL mode...it will keep ringing and never answer. It should be set to FAX. mode.
Mar 15, 2010 | Office Equipment & Supplies
Not receiving fax
check the mode of receving auto or mannual change the ring pattern.
Jan 14, 2010 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
I cannot receive faxes. The machine rings, the
check to see how the rx mode is set up as it may be set to manual it should be auto.. this means if a fax comes in you will have to lift phone or pressthe start button to receive the fax in manual mode whereas the auto or fax mode will turn the fax on automatically
Aug 13, 2009 | Office Equipment & Supplies
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
I have the HP640 Fax machine and I'm trying to program the distinctive ring mode but when I follow the instruction which state to press the menu button and scroll to advanced fax and press ok and then it...
I had been confused for the past ten months on this issue and just figured it out! Get a distinctive ring from you telephone service. If you have a answering machine, set it to answer on the 4th ring. On the fax, press menue til you get to the BASIC FAX, press OK, scroll the arrow button til you get to the DISTINCTIVE RING, press OK. Call your special fax number assigned from the telephone co, the machine should read DRPD OK, then on the face of the hp640 on the left i believe is a button called Rcv. Mode/Contrast, press that til you get to DRPD Mode, press OK. It should work great!! Hope this helps.
Jun 17, 2008 | HP 640 Inkjet Fax Machine
Receving fax
how do you fax a paper off?
Nov 27, 2007 | Lexmark X63 InkJet Printer
Faxmachine
CHECK 1.DO YOU GET DIAL TONE ON -ON HOOK DIAL BUTTON OR ON THE HANDSET ? IF NOT PLS CHECK THE PHONE LINE OTHERWISE--- 2.TRY RINGING THE MACHINE FROM OTHER PHONE,CAN U HEAR THE RING ? IF YES ,PLS CHECK WHAT NOS OF RINGS ,THE MACHINE IS SET TO RECEIVE, AS WELL AS SET THE CORRECT RECEIVE MODE , I.E. FAX /TEL/ANS-FAX... 3 IF U STILL DON'T GET FAX TONE WHILE RECEVING ,THEN TELEPHONE LINE CARD SHOULD BE BAD... TRY REPLACING TEH SAME ,SHOULD RESOLVE THE PROBLEM. HAPPY FAXING OMNIPRESENT HAPPY FAXING
Sep 21, 2007 | Office Equipment & Supplies
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
146 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
