Question about Conair Weight Watchers WW-87 Body Fat Glass Scale
Scale appears to be inaccurate
Every time I step on the scale I get a different weight. It varies within several pounds. I let the scale go off, tap it, wait for it to reset, and then stand on it without moving. I can't even get the same weight twice. Is it likely that the scale is defective? I have little experience with digital scales, but thought it would be more accurate than analog, not less!
  • 1 more comment
  • kevgarit Dec 23, 2008
    I have the same problem, changes frequently between 5 lbs. very discouraging while trying to lose weight because you cant trust the numbers on the scale. Also the first and only solution posted means nothing unless it is clarified. Do end users change the load balancer dohickey?
  • Anonymous Mar 24, 2014
    Scale Just Displays ERRR Will Not Show Weight
    When I stand on scale, weight does not register - it ticks down from 7 lbs to 0 within a few seconds. How do I reset/reboot scale?
    Problem Solver:
  • 19 Answers
This type of less resoluted scale hasn't repeatability. if you wish to repair it, change the loadcell. use 2 x scale capacity of load cell.
Posted on Dec 02, 2008
I get an "E" every time i step on scale
Stepping on the scale before the "000.0" causes this error message to appear. If "E" appears, step off the scale and repeat initial RESTART by tapping on the center of the scale. Wait for the scale to indicate 00.0 or something like that THEN step on.
Oct 12, 2010 | Health-O-Meter Health O Meter HDM520KD 18...
How do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Jan 15, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
Nothing will display on the read out
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 03, 2010 | Taylor Dgtl Body Fat Scale
My scale keeps giving me an err2 message. How do
1. Take out the battery
2. Put scale on hard surface
3. Stand on scale for five seconds
4. Put battery back in
5. Tap your foot on scale to make 00000 appear
6. When the 00000 disappear tap your foot on scale again and then stand on scale till your weight appears
If this does not work the first time (it has always worked the first time with my scale) the repeat the steps a second time. If the second time does not work call the company because something else is wrong.
Dec 16, 2009 | Taylor Body Fat Analyzer & Scale, Model...
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
How do you program users?
Storing and Recalling Weights
1. Your scale can store and recall up to 5 weights. If your scale has one button,
weights can be stored for one user. If your scale has two buttons (User and
Save/Recall buttons), weights can be stored for multiple users.
2. Tap center of scale platform with foot and wait until "00.0" appears.
3. Stand on the platform without shifting or moving until weight is displayed.
4. For single user scale: When weight reading appears on screen, step off the
scale, press Save/Recall button and hold for about 2 seconds to save the
reading.
For multiple user scale: When weight reading appears on screen, step off the
scale, and press User button to select a user number. Then press Save/Recall
button for 2 seconds to save the reading.
5. Weight reading blinks twice, then becomes stable. A small number (1-5)
appears in the upper right hand corner of your display, indicating which of the
5 weights is displayed. (Once you have 5 weights in memory the current weight
always saves as "1" and the oldest reading is eliminated.)
6. Weight reading is saved. Press Save/Recall button to review the last 5 weights or
let the scale shut down automatically. (Note: until you have 5 weights stored in
memory, the display will show the number and "–" for each weight for which
no data point has been stored yet; i.e. "3 –", "4 –", "5 –" if only 2 weights
have been saved.)
Hope this helps!!
Feb 09, 2009 | Precision Camera Weightwatchers WW70 Body...
Conair WW41 Scale
To totally reset the scale and remove any old data in the users take battery out for 2 hours.
To use the USER functions:
Tap scale to turn it on
When you see "0.0" press
Press SET button. "P-1" will appear and blink
Use UP/DOWN button to select a user number
once desired user number (1-4) appears press SET button to confirm
when 0.0 appears step on scale this will enter your starting weight
press SET to confirm
scale automatically sets a goal weight of 10% below starting. you can raise or lower it by using arrow buttons-Press SET to confirm
Tracking weight
tap, see 0, select user number. Scale displays start weight, then goal weight then 0.0 and you weigh yourself. In the smaller windows it will display last weight and the difference between current and last weight then diff between current and start then diff between current and goal
Aug 24, 2008 | Health & Beauty
Conair Weight Watchers WW-87 Body Fat Glass Scale Logo
1,588 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
