Question about Kicker CompVR 05CVR84 Car Subwoofer
Knocking noise with my kicker compvr 15"
I have 2 kicker 15" compvr's i have a brand new lanzar amp its a 2400w amp and the speakers a 1000w a piece. i never really turned it up the whole way or overloaded the sub's but the one has a harder knocking sound at the peak of a bass hit i dont know what to do i thinks its either the one speaker is not hitting as hard or the other one is about to blow please help idk what ot do
  • shawnnaid007 May 11, 2010
    are both the woofers running of the same amp?
    Check the erathing of the amp that is running the woofers.
  • 15,935 Answers
Comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Posted on Dec 22, 2008
I have 2 12s kicker comps 2ohm. One of them are working fine, the other one, when I hook up to amp, it throws them both off and just does this repetitive bass....or when I just hook the one thats...
Measure the resistance across the voice terminal of the known good sub, and then compare that to that of the problem sub. You may see a greatly changed value, which likely means the voice coil is damaged. Don't connect the subwoofer again because you risk damaging your amp as well.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Nov 16, 2017 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
My subwoofers cut out after 30 seconds of use but work fine during the 30 seconds...my fuses are all fine and i'm running thick wire with an 80 amp fuse connected off battery...I have a lanzar vibe286...
If it's only your subwoofers cutting out and your speakers are still playing and all, try turning gain down on sub amp and see if that fixes it. I know if I crank my amp too high it kicks itself off to try to keep itself from blowing.
Aug 21, 2011 | Car Audio & Video
One of my 15" cvr
if the unit completely stopped working try connecting the speaker to the working speakers connection, if it still doesnt work then you have seized the speaker, basically the driver is shot and the speaker is dead. you might have a warranty but usually you can smell the burnt coil. turn down the gain and the frequency on your amp as it is not properly tuned and will cause dame like this as well. if you are not certin take the car to a install shop and have them tune and balance you system for you.
Mar 07, 2011 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
I have 2 15'' CVRs and a 1200w amp
1 OHM...ONE... sheesh now thats a low resistance for anything... If they are only 500 watts and they are in parallel, series well NO.. your amp puts out wayyyy too much for those speakers.. 1200w versus 500 watts by 2... srill NOT enough "Head room" for it to be safe... about half is all you could expect before Pop.. sound is heard.
Mar 05, 2010 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
Wireing two dual 4 ohm kicker cvr 15s on a memphis pr1000 at a 1 ohm load. I trying to get these kickers to hit harder. Do I need a bigger amp or what?
CVR series do not have large power handling capabilities.
Your subs will melt before the amplifier is used to its full potential.
If the subs arent in a ported enclosure - do that.
They both handle 500w rms - so the pr1000 is perfect.
bass response is all in the enclosure!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
Kicker compVR 12
get a ground loop isolator. and another set of rca's or just run the power wire on the other side of the car let me no if that helps please rate if help full or not
Sep 18, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
How to wire Kicker CompVR 07CVR82
theres many ways to wire it up let me no the specks on the amp
Apr 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
PROTECT LIGHT COMES ON WITH 2 SPEAKERS HOOKED UP
Go to this website page and see if any of this applies to your problem. http://www.caraudiobook.com/car_audio_amplifiers/car_audio_amplifiers.htm
Aug 11, 2007 | Lanzar HTG244 Car Audio Amplifier
Kicker CompVR 05CVR84 Car Subwoofer Logo
484 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
