Question about Philips VR540 VHS VCR
Flashing '2' or '1' or '4' when I try and play a tape
Hi, I've been trying to play tapes on our Philips VCR but it won't work. The connection VCR to TV is fine but when I put in a tape instead of playing it goes straight to grey fuzz on the screen, the VCR seems to turn itself off because you don't get response to any buttons being pushed and the display flashes a number - usually 2, but also 1 or 4. The only button that will respond after that is the standby button - if you press that it goes back to PO1 etc. on the display (showing what's on TV) and the tape ejects. One tape I tried seemed to try and play for a few seconds but all there was were grey squiggles on the screen and no sound. Then the tape got tangled in the mechanism and had to be gently pulled free after unplugging machine. I noticed someone else on this forum got flashing 2's after extracting a tangled tape... and it seemed to be a problem with the tape playing mechanism or gears. Could someone help me... I would like to know if there's anything we can do ourselves or indeed if there is any life left in our machine? thanks
  • Anonymous Nov 12, 2007
    I have exactly the same problem. The VCR works on three out four tapes. One tape tape gives the flashing '2' and then '4'
  • Anonymous Mar 12, 2014
    when u put a tape in, the display on the vcr starts flashing for a while. when it stops u can press a button on the panel and it might work or it will start flashing again
The idler on your machine needs to be changed and also the drum head of your machine needs to be clean.tape head cleaners can be bought from any electronic shop.the idler must be changed by qualified techn
Posted on Jan 27, 2007
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Vcr/dvd combo, vcr no longer will play tape, when I press play, after a few seconds will eject tape.
Hi
Thanks for using FixYa. Please check the eject mechanism and the drive motor connected with the tape mechanism. Try and align the drive motor. Also check the push-pull arm of the tape mechanism and make sure that the springs connected with the mechanism are fine.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Dew light is on vcr and will not play tape what can I do
take a hair dryer on low setting and try to blow warm air into the vcr to warm it up until light goes out
Jun 11, 2009 | Audiovox AVP7000 VCR
Philips DVP 3200V/37
Hey there, Here are some ideas; I would clean it one more time to make sure that its nice and clean try playing a different tape on your VCR and check the channel on your VCR, and thats if you are using a channel 3 or 4 on your VCR, concur with each other. Meaning if you have Channel 3 on your TV you should have Channel 3 on your VCR. Thats a really old method. If you use a coxial cable unplug it and replug it in again sometimes there is no contact at one of the ends therefore disconnecting or connecting it again would help. Just see if that works and usually that was the problem when i use to have problems with my VCR. Let me know if that works out for you alright.
Oct 04, 2008 | Philips VR621CAT VHS/S-VHS playback VCR
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Philips vr630 vhs
I get the same problem with one tape (it's about 20 minutes long) .. it also shows a '4' ... when you press the power button it ejects the tape... some tapes are fine ...
Jul 14, 2006 | Philips VR630 VHS VCR
Philips VR540 VHS VCR Logo
831 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
