Question about Saeco VIA Venezia
Machine does not stop after dispensing two shots of espresso
The espresso turns out fine and everything seems to be working fine except the machine will not stop after dispensing the two shots of espresso. I have to manually turn off the unit to get it to stop dispensing the espresso.
Any ideas would be appreciated! Thanks
  • Anonymous Mar 22, 2014
    seems to work fine ands sounds good but no espresso
    Scholar:
  • 65 Answers
That kind of machine is pretty well engineered!Very solid and work on a basic deal.The problem could be just the simple on/off button.
The pump is controlled by the button and if the button don`t stop the machine still understanding you need more until you close the circuit.Sometimes coukld be also a loose wire.
In some way you are lucky because that machine have not electronic board so...less part.....less problem
Don`t forget to rate your experiene
Fabio
Posted on Dec 02, 2008
Coffe Machine Saeco Magic Comfort
the coffee beans grinder is too fine .Turn to next number,
Oct 29, 2013 | Saeco Magic Comfort Plus Espresso Machine
Whenever I try and pull a shot on my espresso machine, the "constant flow" led starts blinking, and water will not stop dispensing until I hit the "stop" button (does not stop...
There is a problem with the flowmeter, it is located under the drain tray with 3 electrical connectors to it. The flashing means it cannot read the magnet on the wheel. You might have to replace the flowmeter. First try programming a button on the side that is not working, if it does not hold the program then it is the flowmeter.
Jun 03, 2011 | Nuova Simonelli Mac 2000 Espresso Machine
When pressing the "start/stop' button
the pump is not getting water, make sure it does
Nov 11, 2017 | Nuova Simonelli Mac 2000 I Group Espresso...
How do I increase grouphead pressure on la marzocco linea 2 group?
To increase dispense pressure you turn the adjustment screw at the pump. When pulling a shot (use espresso) on one group the bottom needle of the gauge should read 9bars while pulling the shot.
Dec 16, 2010 | La Marzocco Linea Series Group 3 Espresso...
Milk frothing wand will not opporate
Check the end of the steam pipe, it might be blocked. If not then the machine is block where the pipe to the steam valve sits on the boiler.
Aug 08, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Briel MultiPro Series The machine suddenly stopped heating. Everything works fine except that coffee comes out cold. There is no way to heat up water. Which part could be deffect?
Possibly bad heating element which is inside thermoblock. Can purchase for $75. Contact Fank at ElectraCraft Phone (201) 439-1700 to help you troubleshoot.
Mar 15, 2009 | Briel Multi-Pro ES-200A Espresso Machine
Gaggia baby dose d (circa 2007) wont dispense water? pump?
Sounds like it needs descaling - not the normal descaling but inside the pump head!
Oct 25, 2008 | Gaggia Baby Espresso Machine
Machine stopped working
This machine is piece of s... I replaced two of them so far and experienced same problem.:
Machine works fine couple days
...than it start dispensing less water into the cup.
...than it stop dispensing water into cup completely and instead all water goes into the tray.
..The pump also starts occasionaly to make interrupted repetative sound.
Did anybody get it fixed?
Jan 05, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Weak coffee shots
Need a decent grinder or a deft hand with a blade frinder, fresh espresso coffee beans and not too much water. Espresso grind is closer to turkish than drip. Much like Melitta grind. If needed a good coffee shop will grind it for you. A week suppply is preferable. If quantity of water can be adjusted, one shot is about 1&3/4 oz. a double shot, well x2=3.5 oz. You cannot get a six ounces espresso and still call it that; its dilluted or "allonge". A latte w/o milk. Let me know
Dec 29, 2007 | Saeco 762111651808 Espresso Machine
Saeco VIA Venezia Logo
96 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
