Question about Kitchen Ranges
The fan of my oven is not working. Is it easy to fix or should I call for service Oven: St George, UEE01 Series, Single Wall Oven, Pull-Down opening. Thank You, N.K.
It was easy this time, a wire was loose.
Thank you,
Posted on Nov 26, 2008
St George wall oven wdl370 no power to the oven, yet the upper & lower grills work. I have checked the fuses and all okay. Thanks
check the elements and the oven safety valve? and check for separate fuse to oven?
Mar 08, 2015 | Ovens
DEO-6 top oven doesn't heat when fan oven is used
check wiring to cavity air pressure switch terminals eg the two wires should be connected to common(c) and Normally open (NO)
May 16, 2010 | Ovens
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Dec 09, 2009 | Maytag 24" Built-In Single Electric Wall...
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
Delonghi oven grill broken, oven still works?
You will probably find it is the grill element that is faulty, a common fault on your brand of oven, to be certain, you need a meter to test it.
Please rate my solution.
Jul 15, 2009 | DeLonghi Ovens
Hi, we have a St George wall oven that is making a loud rattling noise that starts when the oven is heated and then comtinues after the oven is turned off. Any ideas on what might be the problem?
there is a casing fan which is out of sight and that is what is making the noise. take oven out, remove top and fan will be revealed. may have to be replaced or possibly try a squirt of wd40
Oct 02, 2008 | Kitchen Ranges
Kitchen Ranges Logo
210 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
