Question about Kenmore Dishwashers
PUSH START BUTTON AND IT WONT START
I PUSH THE START BUTTON TO START THE DISH WASHER BUT IT AUTOMATICALLY GOES TO CANCEL / CLEAN
  • popplace Nov 26, 2008
    yea that didnt work
    what it does is i push the buttons that i want the cycle to be on then push start and it automatically goes to the cancel/ clean stage. and it will not let me do anything else
    i dont know but i do know this dish washer is a piece of **** and it is even worse that i have to pay for some one to help me with my problem... that is bull
    President:
  • 2,712 Answers
The keypad will have to be replaced. There is a short in there somewhere.
Better solution? Get yourself a nice new dishwasher if you've been having issues with this one..
Posted on Nov 26, 2008
  • 728 Answers
You may have a key pad short or the button may be messed up. The key pad should be able to be replaced and cheaply. Also make sure the door is completely closed or it will not start.
  • Kenmore Master
  • 19,396 Answers
Try unplugging the power cord for ten minutes.
Check the drain hose and the water supply at the back, ensure that the door is well closed.
  • Ginko
    Ginko Nov 26, 2008
    First unplug the power cord for ten minutes and try again, this will reset the control circuits.
    Check the drain hose, see that there is not obstruction.
    Check the water supply at the back, ensure that water is fowing inside the machine.
    Ensure that the door is well closed, and that the door sensor is not stuck, otherwise it will go automatically to cancel.
    See also the following suggestions from Repairclinic:
    It doesn't work at all
    If your dishwasher doesn't work at all, check these:
    Power from the house
    Door switch
    Wiring
    Timer or selector switch
    Is
    there power getting to the dishwasher? This can be difficult to test,
    because dishwashers are usually wired directly to an electrical
    circuit, rather than plugged into the wall. But at least check for a
    blown fuse or a tripped circuit breaker.
    Door switch
    The
    door switch is important because, if it's defective, the dishwasher
    won't work at all. To reach it, you need to remove the control panel
    cover, or sometimes the interior liner of the door. If it's defective,
    you need to completely replace it.
    Wiring
    Often
    the main wiring connection from the house, at the dishwasher, burns and
    breaks the connection. If that's the problem, the wires must be
    repaired/replaced as necessary. If that's not the problem, check the
    wiring to the door switch, the wiring between the door and the lower
    part of the dishwasher, and the wiring to the timer. Repair any broken,
    burned, brittle, or defective wiring, using the proper appliance-grade
    wire and connectors.
    Although
    it's uncommon, the timer or the selector switch may be defective. If
    so, you need to replace the defective part, because neither of these
    can be repaired.
My door on the dish washer wont open
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock.
IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
Good luck and thanks for visiting.
Oct 03, 2010 | Admiral Dishwashers
Washer will not spin clothes dry...full of water and wont work. f-21 keeps flashing.
your drain pump is clogged,So the first thing you need to do is,Push the start button again you well hear the machine come on you well hear the pump its trying to drain after about 30 seconds,It well shut off,so push button again watch the machine when the water goes down a certain level.The clothes well start to spin. Now after they get done spinning,push the cancel button.you should be able to hear the door unlock,remove the clothes.Now put Draino Max gel or Rooto-Routor gel in tub of machine and let it set for about 1-2hrs.Now star cycle on heavy-duty wash hot water,it may take a couple of times but it well clean your machine don't mix any othe soaps or bleach during this time. then rinse machine out again to get rid of gel.see if this work for you,are machine does the same thing,its because of dog or cat hair,or something was in a pocket like tissue,or strings from clothes.thanks
Jul 29, 2010 | Kenmore HE2 Plus Front Load Washer
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
I start the machine the suds flashes then it goes away and the F35 flashes and nothing happends I tried to use the clean washer cycle and it still comes up F35 then when I try to push the cancel button the...
If this is a steam unit you have a bad analog pressure switch,has been a common issue in those units,Gives an F35 core and sometimes a SUD code.
Sep 20, 2009 | Washing Machines
Need to reset washer it is stuck in mid cycle and wont continue nor start over
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
cheers
Jul 24, 2017 | GE WBVH6240F Front Load Washer
Error Message
Your owner's manual may give a troubleshooting guide for the error code your machine might give you. Is it possible you have locked out the control panel? I "think" the calypso has a control lockout, usually a start button or cancel button. If you press it in for 3-5 seconds, it can lock or unlock panel. If all else fails, try unplugging it and see it it will drain out the water.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Dish washer wont come on
there is a thermal fuse connected to the control board in the main console that is probable blown
Mar 01, 2009 | Dishwashers
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Dishwasher won't start
jamcdani Most likely the problem with your dish washer is bad key pad. It is not repairable and has to be replaced. Whirlpool does not sell it separate and you have to by the whole console assembly. The price range is between $95 and $115 (different colors) and it is not very complicated to replace it. I can help you with the complete step by step instructions and, if you provide the complete model number of your dish washer, I get the part number and the best price for you. Gendos post back...
Jun 29, 2007 | Whirlpool 24 in. DU915PWP Built-in...
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
