Question about Kowa TSN-822
Eyepiece problem The eyepiece of my scope easily falls off when i switch magnification from 20x to 60x. Can anybody suggest solutions on how to solve the problem? Thank you.
  • 10865 Answers
SOURCE: I have a Kowa TSN-
hello alexan..... I have first hand knowledge of Kowa and the answer to your question is yes. The company has an east coast service rep. and a west coast rep. Go to the link below to contact one of these service reps.
Posted on Apr 22, 2011
0 characters
1 Points
I have a Bushnell Voyager telescope and can't see anything thru it at night!
Did you set it up according to the provided instructions?
Do you have a low power eyepiece inserted at the viewing end?
Have you aimed the telescope at the moon as a basic test of
If your telescope is not properly aimed at the target (a star or a planet, or other object in the night sky) then you will see nothing.
If the power of your eyepiece is too large and your telescope aim is
not "dead on", then you will see nothing.
Have you tried using the scope in the daytime? Do you see anything?
Aim at a specific object, or section of an object, like the top of a lamp-post about a block or two away, and see if you can focus on
it the eyepiece.
You really need someone at your side who has experience in using
astronomical telescopes. That would be the quickest way to solve
any problems you have.
Unless your question is very specific, and unless you provide as
much detail as possible about your problem, it will be difficult for
anyone to provide you with speecific answers that will help you
solve your problem.
May 06, 2014 | Bushnell 789961 Voyager Sky Tour 700mm X...
Konus Spot 80
I understand your frustration!
Please try to contact their US service center:
7275 NW 87th Ave.
MIAMI FL 33178
tel. +1 305 5925500
fax +1 305 5926255
Jan 02, 2008 | Konuspot 80 (20-60x80 mm)
Need 80mm eyecepie,for swift spotting scope #821.
Sep 07, 2009 | Swift Spotting Scopes
Tuning up a Fujinon Super 80 (used)
yuh,why not try a lag bolt,seems like it couldnt hurt. how much was the scope.maybe the lag bolt will cost more
Dec 17, 2008 | Fujinon Super 80 (25x80 mm)
I have a WO IBIS 80 APO Spotting Scope. How do use it with other 1 1/4" eyepieces? The packaged zoom eyepiece seems to have a threaded attachment to the scope.
sounds like it was designed to use only the eyepiece that came with it. here is an idea...mount the scope on a tripod with no eyepiece in take an 1 1/4" eyepice and place against the scope where you would put the eyepiece ..try to focus..if you cant, then slowly bring the eyepiece away from the scope till you see a sharp sure a machine shop can make a sleeve to screw into your scope and hold 1 1/4" at that point.any questions i can answer call me 5088331232
Nov 29, 2008 | Spotting Scopes
ETX-90 Focus
I suggest trying a different eyepiece first to see if that's the problem. Otherwise, if it was moved without adequate protection, there is a chance the mirror was shifted or damaged. A damaged mirror can't really be fixed since it's specs are very rigid. If it turns out to be a problem with the mirror the best thing to do is find an expert on telescope mirrors to try and fix the problem.
Nov 12, 2007 | Meade ETX-90 (48x90 mm)
Tasco propoint PDP2 scope
Are you looking set the eye relief or the focus ring?
For eye relief you need to loosen the scope in the rings, mount the rifle to your shoulder with your standard hold and cheek weld. At this point, slide the scope back and forth in the rings until you obtain a full field of view. Tighten one of the rings slightly, dismount and remount the rifle several times to ensure correct adjustment. Level scope and tighten rings a final time.
For focus adjustment (remember that you are using the eyepiece to focus on the cross hair, not your target!) loosen the lock ring and turn the eyepiece until the cross hair is focused. It is best if you check it several times by closing and opening your eye several times. The crosshair should be instantly in focus. If your eye must adjust, then you need to refocus until the focus is instant.
The two dials on the scope are for adjusting the bullet point of impact. They will typically move POI 1/4 inch at 100 yards.
Nov 08, 2007 | Spotting Scopes
Kowa TSN-822 Logo
41 people viewed this question
Top Kowa Spotting Scopes Experts
Michael Thomas
Michael Thomas
Are you a Kowa Spotting Scope Expert? Answer questions, earn points and help others
