Question about LG VX8300 Cellular Phone
LG VX8300 Shutting off by itself
Sometimes my phone is off when I open it. The battery is charged. It just seems to be shutting off by itself. Any ideas what may be wrong? And is it fixable?
  • 2 more comments
  • pejanders Dec 03, 2008
    I have my LG VX8300 about a year and just recently started having the same problem. I'll flip it open and it's just turned itself off.
  • jimshari Dec 07, 2008
    Battery is fully charged and phone keeps shutting itself off.
  • leemarsha Dec 18, 2008
    Phone randomly shuts off, w/o tones. Battery fully charged.
  • Anonymous Feb 02, 2009
    same problem. whatever it's a pain
I had the same problem on 2 phones.
I cleaned the contacts on the battery with 600 grit wet/dry (black) sandpaper (dry).
No problems in the last 5 days.
Alcohol probably would have worked just as well.
Good Luck.
Posted on Mar 02, 2009
    Problem Solver:
  • 3 Answers
You may just have a screw loose - literally.
I've had this same thing going on for several months now. I will pick up my VX8300 only to see it's completely dark; I'll do that lengthy startup routine to find that umpty people have been calling and are wondering where the hell I've been - so I have to tell them that my &!#%*! phone has been AWOL. I've also experienced the phone shutting off abruptly when I close the case. I stumbled onto a possible solution mostly by accident - I say "possible" because it *seems* to have worked, but since it's only been a day or so I'm not yet certain:
Clear a space at a desk or table and open the battery compartment, being careful of...loose screws. When you've taken out the battery you should see four tiny phillips-head screws that hold the front/back halves of the bottom (keypad) section of the phone together. On my phone, one of these fell out on the desk, another was missing altogether and the other two were loose enough to where I could hold up the phone and see a gap between those halves close when I squeezed them together.
I happened to have one of those cheapo eyeglass repair kits that you find at the local Walgreens or Rite-Aid (please support the CVS boycott, thanks,) and it turns out that not only do the tiny flat-blade screwdrivers for eyeglasses work to tighten the Phillips-head screws (though an actual Philips-head jeweler's screwdriver would be best,) the little spare screws included with the repair kit fit perfectly, so I was able to use one of them to replace the missing screw. Use common sense on torque - get the screws plenty snug but don't try to muscle them in to where the case cracks or the threads strip. If you've got a bottle of Loctite laying around use that on the screws....like LG *should* have in the first place. (I've been rejecting Verizon's pleas that I "upgrade" to a newer phone, mostly because I don't need to carry a virtual entertainment center around with me and have no desire to impress random, disinterested strangers with My Snazzy Cel. Plus, I generally like the VX8300 despite LG's having killed the VX6000's excellent voice-dial feature.)
Anyhow, since I tightened the four screws and put the battery in and cover back on, I've had no more sudden power-downs, even when I snap the case closed vigorously. I'm not sure if this is the complete solution, nor if it is, why loose case halves would cause the blackouts, but it seems to have worked. Give it a try.
Posted on Sep 11, 2009
  •  Ellis
    Ellis Sep 22, 2009
    Update: Tightening the screws inside the battery compartment has solved the power-down problem entirely for me. It's been 11 days since I did that fix and the phone hasn't powered off by itself once. I haven't done anything else differently. There must be something that shorts against something else when the case halves move around. Snug 'em down.
My cell phone won't charge or turn on when I plug it in.
this generally indicates a bad battery, try to purchase a replacement battery
if this does not fix the problem, then sorry to say, but the phone is shot, it is older now
Dec 22, 2013 | LG VX8300 Cellular Phone
Lg vx8300 turns off when flipped open
Try charging the phone upside down. The charging port inside the phone might be loose
Oct 14, 2009 | LG VX8300 Cellular Phone
I have the same problem
your batterry is too weak or weak amperage for your cellphone you need to replace it a new one battery.
Aug 01, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
LG ENV2 shutting off
I just got mine a few weeks ago and it does the same exact thing (I didn't drop it, there is no water damage, I didn't understand the cause of it). I took it back to the Verizon store and I was told that the random shutting off like that is caused by having the phone outside being exposed to heat. He reset my phone back to factory settings and that did the trick for awhile (its hard for me to go to the pool and not have my phone exposed to the heat). There is no charge for them to reset the phone. Mine has started the random shutting off again back up
Jun 03, 2009 | LG enV VX9900 Cellular Phone
Viore DLP TV keeps shutting itself off
contact lg at 800-423-000. they may cover the repair. They might charge you a small trip fee and cover the part. sounds like the pwr supply is shutting down.
Dec 06, 2008 | LG 42LC2D 42 in. LCD HDTV
Wold clock display
You will need to reset the phone in it's settings
Dec 05, 2008 | LG VX8300 Cellular Phone
LG vx8300-after getting a new battery the phone just about went dead in 3 days. When charger is on, the screen just says verizon wireless and then sometimes displays the battery is charging. When...
Is the battery the same type as the previous one? If not try to find if the one you have purchased can be used with your phone. In the case the battery is compatible with your phone, since you are having problems, just return it to the store you bought it from, cause there is high chance it is destroyed.
Nov 23, 2008 | Lands Phones
LG vx8300 phone will not turn on
dunno. try to have it on the charger, and at the same time try to push and hold the power button. try it a couple times. my v180 from motorola did that and it seemed to work.
Sep 18, 2007 | LG VX8300 Cellular Phone
LG VX8300 Cellular Phone Logo
432 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
