Question about Breville BES400 Espresso Machine
My Breville Ikon Espresso machine does not make coffee. No water comes out of the coffee head.... The steam wand works fine. I'm just trying to do the Priming and no water comes out of the brew head.
  • 1,847 Answers
Clean the Interior
  1. Use a commercial espresso machine cleaner or use vinegar and water to decalcify the inside.
    • To decalcify using vinegar add 3 oz. of vinegar to 20 oz. of water, and let it run through the machine. Then run about 3-4 times the amount of fresh water.
  2. If you can disassemble the frothing wand, do so - and get the wand clean. If little rubber gaskets pop out, DON'T LOSE THEM and remember what order they go back on.
  3. Clean the brewhead as you did above. The brewhead is where the water comes out, most pump machines have a brewhead that can be removed with a single screw - tilt your machine on its side (make sure there's no water in it) and disassemble that part. Use toothbrushes, use a clean j-cloth, whatever it takes to get all the nooks and crannies.
  4. Once the machine is cleaned inside and out, run one more full batch of water through it, making sure you stop the pump just before all the water drains out.
Posted on Nov 26, 2008
My Breville BES820XL isn't steaming the milk. Instead it drips a little and then the steam comes out the shower head. Any idea what is causing this and how to fix it?
Maybe the end of the steam wand is clogged. Use the tool that comes with the maker to clean it. Do this with the coffee maker turned off.
May 06, 2015 | Breville BES820XL Espresso Machine
My breville cafe roma wand is not steaming it is just making air bubbles
Have you tried cleaning out the machine? My steam wand started just spraying out a steady stream of water but was not heating up. I used the cleaning solution CLR (8 parts water, 1 part CLR) and let it run through the steam wand for awhile. At first it just kept streaming out then all of a sudden it stopped. I still kept it on just to see what would happen. After about 10 seconds all of a sudden the steam wand shot out whatever had clogged it and it works perfectly again! I had only used the machine about 10 times before this happened. I had not been cleaning it well after each use back then. Now I definitely do.
Sep 13, 2010 | Breville ESP8XL Espresso Machine
Low pressure from steam wand
It sounds like calcium has built up in the machine. Try running pure vinegar through the machine a couple of times. Hopefully that will clean out the calcium and it will start working again. I had the same deal with a coffee pot that took forever to run the water through. After two sessions of vinegar it worked like new
Jul 01, 2017 | Breville ESP8XL Espresso Machine
Cafe Roma producing more water than steam
you really need to decalc frequently, at least every 2 months. after it goes too long, you will see that problem. have not figured out yet how to fix it.
Jun 18, 2009 | Breville ESP8XL Espresso Machine
Extremely loud squealing noise during steaming milk
This could be blocked. The best way to clear this is to switch off the machine and see if you can dismantle the frother arm. Sometimes the arm will come off by unscrewing. If it does, wash it in hot water and washing liquid. If it doesn't come off try putting the frother wand into a mug of cold water and allow it just to steam the water.
Frother wands don't just steam liquids - they **** up liquid which can block the vents and the actual steam hole which this machines' problem sounds like it does have.
Apr 05, 2009 | Breville ESP8XL Espresso Machine
Chrome on steam wand wearing off
Posted by
I have a Breville Die Cast 800ESXL and due to wrong cleaning process, I have to buy the steam wand. I tryed to find them in but they does not have this part available for sale. Where can I buy this Steam Wand for my Breville Die Cast 800ESXL.
PLease let me know ASAP, at
Oct 12, 2008 | Breville Die Cast 800ESXL Espresso Machine
Steam wand, little water coming out, but no steam?
If you look at the end on the steam pipe you will see a nipple, loosen this and make sure it is clean.
Jul 25, 2008 | Breville ESP8XL Espresso Machine
Steam from brew head, but no water
  1. If you take the coffee filter and head it in light, can you see a little hole in the middle? if not, try to clean it else you have to replace it.
  2. Can you brew out water without the filter holder in the machine? If not, loosen the screw in the middle on the machine where the filterholder shall be and take of the filter. Clean the filter and put it on the machine again.
Hope this help you
Jun 10, 2008 | Breville ESP8XL Espresso Machine
Breville BES400 Espresso Machine Logo
1,111 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
