Question about Toshiba Satellite A105-S4004 Notebook
Toshiba laptop does not show windows info.
When moving laptop screen lose picture
    Problem Solver:
  • 13 Answers
If your screen flickers when you move the screen it might just be a loose cable connection. There is usually a panel right above the keyboard that will pop off fairly easy. Make sure all of the cables are seated well.
Posted on Nov 26, 2008
Toshiba c855 screen went black
Try to reinstall windows formatting your Hard Drive... It seems to be an windows crash, or some software.
May 10, 2013 | Compaq Presario Computers & Internet
I own a Toshibe Satellite L350D-215 running windows 7, when I power on the laptop it brings up the Toshiba welcome screen then loads a screen stating that there is or has been a problem and you have...
Sounds like you need to run the recovery disk
If your have the Recovery Disk put it in and boot from cd/dvd,
[Push "F12" at the Toshiba boot screen to access the Boot Menu]
you will loss all your info,,
to save your info [pic's] you will need to plug your hard drive into a desktop with sata.. and back up you info that way then run the disk
if you dont have the disk you will need to get a new windows 7 dvd or contact toshiba for a new Recovery Disk set,
Some times they put the Recovery on the hard drive but i think you need the disk with this one.
May 16, 2010 | Toshiba Satellite L305D-S5874 Laptop
When i try to boot my toshiba it goes to a windows error recovery screen.. it has two options fixed problems and start windows normally... neither ones work... and i can't even boot from the windows disc....
Hello and thank you for using Fixya's services.
The only option here is to restore your computer to factory settings. You will lose all of your information including pictures, music, etc.
Are you running Windows Vista? If so, turn the computer on, press F4, choose advanced and you will see the option to do a factory restore. You can aslo try the other options first such as windows restore and it may fix the file.
Last resort is the factory restore but you are at that point.
Please let me know if you have any questions.
Nov 10, 2009 | Toshiba Satellite A135 Notebook
I have a toshiba a135. the screen has a red color to it. i replace the power inverter and the lcd screen but nothing changed. I was putting it back togeather and i was moving the lcd screen and the redness...
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 12, 2009 | Toshiba SatelliteĀ® A135-S2266 PC Notebook
Windows Won't Load
Same thing happened to me. Looks like your windows install is damaged. My advice, do a fresh install of windows. You won't lose any of your files, but you will have to reinstall most of your software and drivers.
Jul 01, 2009 | Toshiba Satellite L355D-S7815 Notebook
Blank screen on Toshiba Laptop
you may need to restore the computer. any questions you can email me at meanness628@aim.com
Jun 05, 2009 | Toshiba Satellite M105-S3041Notebook
Toshiba laptop satellite A100-332
Toshiba has a problem with the connector from the LCD to the board which breaks over time. You will need to replace it. Here is a sample of what the part looks like. You will need to specify your model.
This one is from a DELL, the one below is from a Toshiba. This went bad even though the client never used the notebook as a portable. It sat on a desk for years and was never moved.
Nov 26, 2008 | Computers & Internet
USE LAPTOP ON TV & LAPTOP AT THE SAME TIME
dear sir
yes i can help u strongly... first of all u have to turn of laptop then connect yr laptop and tv then turn laptop on now when windows appeair. laptop screen has icon and other has plane wallpaper so now go to display propaties ( click on desktop>go to propaties>setting> now it's show's 2 monitor screen on display screen click in inditeficate... how it's show "Expand display " somthing like that just remove select earrow now click apply... if it's not worked go to advance then go to adaptor setting and find display setting and select "CLONE" it's male both laptop and tv screen as same...it's help u...:)
Thanks
please vote
jo_chinmay
Oct 06, 2008 | Toshiba P000347580 - Satellite 1400&2400...
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
