Question about DHD NTX-6612 Car Subwoofer
DHD ntx6408 subs
Subs were in a box and looks brand spanking new. But when connected no sounds whatsoever. check all leads and connections, amp is working and plays on other speakers. DHD subs looks brand new does not smell burnt or any kind of visual damage. Even try to hook to house system and still no sound. Please Help
  • Nono Syhaphom Jan 06, 2007
    Is there any way to fix this or is it cheaper to buy new one. But if you could i WOULD LIKE TO LEARN HOW TO REPAIR SPEAKERS
    Scholar:
  • 72 Answers
Voice coil has been blown open. Most likely alot of times what I do to test a speaker is connect it to a 9 volt battery. on and off and the speaker should bounce. If not speaker is blown. Plus this way you could save yourself lots of problems. If the speaker was shorted and not blown open. You would now possible have a blown amp and home stereo.
Posted on Jan 06, 2007
Dhd amp has power but blue leds flash once and turn off. the led in the back lights up green but the blue leds that light up in the front flashon once, and then turn off. it won't let me sub hit.
Dhd amplifierDisconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Feb 05, 2015 | Audio Players & Recorders
I have 2 of these brand new in a ported box in my
this could be your connection to the amp .make sure the positive leads from the sub are on the positive terminals on the amp .first try one sub alone and then connect the other one .with the second one try swaping the terminals but if your using quality products you woudnt have to just connect the leads to the terminals the belong to .positive on positive and negative on negative
Apr 21, 2010 | Jl Audio 12W1v2-4 Car Subwoofer
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
The light on my amp is green but no sound
have you got the auto ariel lead from the head unit connected to the remote connection on your amp?
if not then that is your problem, it turns the power on when you turn on the unit. and turns it off when you switch unit off.
hope this helps
Mar 18, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Cd/dvd not recognising anything
check if you have connected the dvd/rom according to the specifications entered. if no then do it and check again if the player reads the disk. if the problem persists, and i you suspect its the manufacturer's error, then you can get a free replacement according to the warranty details
Jun 06, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
I've got a DHD Ntx2114 that a want to hook up to a diamond audio D610d4 wich is a 10' sub dual voice coil 4 ohm. and i would like to get it hooked up the best way i can so it sounds the best that it can...
if your talking box and all, i would say put it in a ported box ( or you can port your own if you know how) other than that make sure they're hooked up at 4 ohms (look up subwoofer wiring diagrams on the internet if you need to be sure) you can mess your sub or amp up going to low on ohms....less ohms = more power.......i hope this is what you were asking....let me know
Mar 08, 2009 | DHD NTX-2114 Car Audio Amplifier
Premier sub used to work great ... now nothing
Did you check to make sure that you didn't blow a channel in the amp? Another thing to check would be the connection on the inside of your box, maybe there is just a wire loose.
Dec 19, 2008 | Pioneer TS-W3004SPL Premier 12" SPL...
Alpine MRP-M650 : Power LED turns on but no sound. All the connections are made. Subs have been tested on another amp.
is the remote lead properly connected to the head unit? if the power led is on then the power cable and earth must be good, check the remote lead 2 your head unit first, if thats all good try looking at the amp to see whether theres a small switch to adjust the output going to the subs, if its very low or right off then nothing will be going through to the subs. if its on high and fine it only realy leaves the neg and pos inputs from the amp 2 the subs.
cheers, adam
Oct 30, 2007 | Alpine MRP-M650 Car Audio Amplifier
Sub does not fully work
My guess is that one of your subs has a damaged voice coil, which acts like a short circuit to the speaker outputs. If you put an ohmmeter on the speaker terminals you should measure a resistance of not much less than 2 ohms (assuming you've wired the VC's in parallel). If you measure a significantly lower resistance then you have a damaged subwoofer.
Mar 13, 2007 | DHD NTX-6812 Car Subwoofer
DHD NTX-6612 Car Subwoofer Logo
170 people viewed this question
Top DHD Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
Tygh Duval
Tygh Duval
Are you a DHD Car Audio and Video Expert? Answer questions, earn points and help others
