Question about Whirlpool Washing Machines
I have wirlpool duet sport with a code f -21 - Whirlpool Washing Machines
  • 5,911 Answers
"F21" is a Long Drain error. Its usually an indication that something is clogged in the drain pump and/or drain lines. The following link explains how to correct:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Now, your diagnostics procedures may differ, but the procedures for accessing and cleaning the pump are the same. It doesn't take much to damage the small drain pumps in these washers. If anything has been caught in the pump impeller or motor for any significant period of time, the pump may be running, but it may NOT be pumping anything. If you perform all procedures outlined in the link provided and the error code reappears, you will need to replace the drain pump.
If you need a replacement drain pump the following websites are great sources to obtain one - searspartsdirect.com, repairclinic.com and pcappliancerepair.com. Just type in your COMPLETE model number to begin your search. All three offer competitive pricing, so take a look at all three. These are the cheapest web sources I have found for appliance parts.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 26, 2008
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
Starts cycle with add a garment light on. after few min f-21 code on with all lights flashs .cleaned drain pump filter. wirlpool duet sport model #wfw8300swd
Whirlpool F21 (and 16, 18, 20 and 22) states 'control unit failure'. Could be poor connections but requires a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 16, 2011 | Whirlpool WFW8300SW
What is error code f 21 on a whirlpool duet sport wfw8300 3.8 cubic washer?
This means that the drain pump is clogged. Tip the machine back and remove the three screws on the bottom panel. The pump has a filter inside. Pull the filter out and clean it, it will fix the issue for sure!
Apr 13, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirlpool washer duet sport is not draining water out and displays error code f-21
Hi
Thanks for using FixYa. Error F21 indicates long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Wirlpool Duel Washer
Could be limescale in the pipes under the sink or blockage in the sink.
Disconnect pump from taps - put bucket under pipe and run tap - if water coughs from that pipe, its the sink not the pump.
Jul 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wirlpool Duet Sport Washer shows no indication of power
That happened to mine I had to replace the "brain" of the washer....the part was about $170. I think it is called the control panel.
There is a test you can run...look in the manual.
Jun 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace whirlpool washer Drum, baffle
Just order a new one from an online parts store and put it in.  The new ones dont screw from behind.  They just snap in. By the way, the rest of the baffles will break as well. So you may as well by a couple.  But there not cheap-You can order them through Sears and pay 23.95 each.
Mar 09, 2009 | Whirlpool 8572546 Duet Sport Stacking Kit
Whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Mar 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
