Question about Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Distorted sound comes and goes
I have reported this to Uverse (AT&T) and they have sent 3 different repairmen out (they don't know what to look for unless it happens while they are here or so they say) and it is still not fixed. Could it be the tv and not the Uverse connection ?
    Sergeant:
    Champion:
  • 227 Answers
I am going to give you the best solution for this problem, not even sharp techs know what the problem is, the only solution is to get the sound from a separate receiver, let me make myself clear, get the audio out put from the satellite or cable box. and connect it to a receiver with separate speakers. the problem is in the sound card and to replace it cost $260.00 + labor and you gonna have the same problem in a few months or it could last a year or 2 two days, who knows, don't waist your money trying to repair it. i have done 3 so far and that is the only solution good luck
Posted on Nov 26, 2008
Tip
How Loud Can it Go?
I don't know if I ever installed a sound system to any concert fan who didn't ask me this question. So how loud can I safely play my sound system?
If you have a receiver or amplifier that has an analog dial that goes from 7 o'clock to 5 o'clock the majority of units will output maximum volume at around 1 o'clock assuming a line level signal is sent to it (again it varies a lot from piece to piece). Anything higher then that and the unit will send out a distorted signal colloquially referred to as "clipping". Most modern units now use digital volume controls and everyone is different. The only way to detect this distortion is listen to when the music sounds tinny and harsh instead of clean and musical.
If you do not find it is loud enough for your liking you must invest in a more powerful amplifier or higher efficiency speakers; or you will continue to destroy your innocent speakers and blame them for your over driven amplifier.
on Jan 27, 2010 | Audio Players & Recorders
Honeywell Lynx plus 3000 wont dial over VOIP cable
usually for most voip like AT&T uverse etc.. you'll need to put in a cell unit into your lynx plus. usually your monthly rate will go up by switching to a cell unit. they'll need to put in a gsmvlp into your panel
Jun 21, 2012 | Honeywell Lynx Plus Wireless Alarm Kit
Ethernet (wired) connection to computer works but "wireless" light does not come on and my laptop cannot locate a wireless access point or network device. It has worked in the past but after...
You will need to get a hold of att. They will need to have you unplug the 2wire and then reconnect. They will need to reset the gateway from their end. good Luck.
Sep 07, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Sound and picture won't always match. It's a sanyo model DP52440 52' HD LCD
It's not your TV. It is your data stream coming from the converter box. Audio is processed and sent very easily whereas video takes processing time, hence the delay. If you have separated you audio from video utilizing an external surround sound system, you must channel your video through the same processor. Very complicated if you don't know how to do all this stuff. Could originate with your provider as well. Cable, satellite, uverse, cat, coax, etc.
Jan 12, 2011 | Televison & Video
I need the 4 digit Hannspree manufacturer code to set up my UVerse remote control
AT&T don't list any codes for Hannspree, but I have it on good authority that either code 1004 or 1018 work for Hannspree. Others have reported that the some of the codes for Vizio TVs will also work. There are: 1489, 1429, 1433, 1439
If none of these codes work, please let me know and I'll try to find some alternatives. It would help if you could let me know the model number of your TV to narrow my search.
I'd also be grateful if you could let me know which, if any, of the above codes worked for future reference.
Regards,
BElectric
Dec 12, 2010 | Televison & Video
Hi, I have a dell inspiron 5100. I have two problems. 1) My screen is completely black and I have to use an external monitor. When I start my laptop, I can see the Dell Logo and after that is when...
for your video problem, you may be stuck in a different mode try holding the Fn key and hit F8 this toggles through the modes
1 - LCD on laptop only
2 - LCD and external Monitor
3 - External monitor Only
if this does not work you may have a LCD issue with the laptop .. let me know how it goes first
Feb 02, 2010 | Dell Inspiron 5100 Laptop
Tv goes black for a sec. every so often also has green glow on bottom and 2 red glows on left and top
I have the same problem on my Sony LCD RP. This happens only on HD channels and only during commercials and roving reporters on news reports!!! Do you use ATT Uverse? I do and I think that might be the problem. I posted the same problem just now under rear projection.
Aug 06, 2009 | Panasonic Televison & Video
Monitor freezes up with multicolor wording or distorted images
Sounds to me like a few possible things...
1) Bad connection to the monitor, check the cable connection, if you see or suspect any damage, buy a new monitor or test with a friend's monitor.
2) Video card could be bad, if it has a video card, you could simply buy a new card to see if it will fix the problem. If the video port is attached to the motherboard (meaning onboard video), the motherboard could be damaged.
3) The motherboard could be bad. Sometimes fried motherboards will garble the screen like this on bootup.
Mar 25, 2009 | IBM Computers & Internet
Open Questions:
Sharp Aquos LC-45GD6U 45 in. LCD HDTV Logo
228 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
