Question about Lands Phones
Static on vtech 5.8 ghz corless phone
I have had my phone about a year. Worked great for 8 months. There are two headsets. The static is so bad I can hardly use the phone. We had not added any new appliances no anything new to have changed the reception. We are with mediacom DSL. If I take the phone to the patio window I get a better reception. This is an area of about 25 square feet in which the static is reduced. Do I need a new battery? Do I need a new phone?
5 Suggested Answers
SOURCE: Constant static and interference
I have the same problem with uniden. I have called the telephone company out 3 times for all the static. They have told me that witht the 5.8 I could have a neighbor using the same phone and have constant static. It is so annoying. I spent alot on this phone and not sure what to do
Posted on Jun 17, 2008
ltfrc
  • 227 Answers
I have found that dimmer switches might be the cause your problem. If you have any around the house you may want to change them to a regular switch.
To test to see if this is the cause, turn all your dimmer switches completely off (not just turned down). See if it clears your static issue.
Posted on Jan 05, 2009
  • 5 Answers
VTech products are generally poorly designed and manufactured. You can probably notice the FCC Warnings on the device that say that you must accept all interference that you may recieve while in use. Go out, splurge a little, and find a telephone made by a well known company like Panasonic, Sony, etc.
Posted on Apr 13, 2009
  • 121 Answers
SOURCE: how to reset my password
Here is a link to all V-Tech owner manuals: http://www.vtechphones.com/vtechphones/index.cfm/support/manuals/
I would have found more specific instructions but you didnt provide Model # for me to locate. Sorry
Hope this helps. Good luck, RJ
It seems as if the factory password is #19. Try hitting #9 and seeing if it will give you the password.
Posted on May 13, 2011
How do i get me white corless vtech phone to register?
Enter the model of your VTech phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Jun 20, 2014 | Vtech Lands Phones
Why are 3 phones saying line in use when it is not?
Hi Dolores,
I have this site for you where you can see the manual of 5.8 GHz Digital Phones. You may want to check the model of the phones that you have in order for you to download the manual. Hope it helps.
5 8 GHz Digital Phone Manuals
Apr 30, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
How to make my 5.8 headset work with my new 6.0 headset
Sorry, you can't. Your new headset uses the DECT 6.0 protocol where your old 5.8GHz headset uses a different protocol. It would be like trying to play a videotape on a DVD player.
Sep 20, 2013 | Vtech IA5854 5.8 GHz Cordless Phone
Phones stopped working. They only read
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
May 29, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Our vtech phones suddenly began to be filled with static, making conversations difficult. The have worked properly for the two or three year we have had them. We have no new electronic devices, nor has...
Thank you for your reply. the problem is in the incoming telephone line and it turns out that other neighbors are having the same static problem. A man from the telephone company is in the neighborhood searching for the cause of the problem. Katsura
Nov 05, 2008 | Vtech Lands Phones
43-139 5.8 Ghz Corless phone
you may need to RESET the handset before getting them registered to the base station. this will ask for a reset code, just consult the user manual to get it.
if you have other issues just let me know
Aug 18, 2008 | Radio Shack 433575 Cordless Phone
No connection
deregister headsets and then run register again
Jun 09, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
Static h700
Good Afternoon.
Has the headset been dropped, or kept in a hot car? The battery could also be going out too, but unlikely if its only 3 months old. Is the headset near the phone? They do have a 10-20 ft range in a perfect condition. But it works best in my tests only a few feet away. As I roam away from the device, it causes static.
Also, is this everywhere you go, or just certain areas?
The reason I ask, if you are near a Wireless network, it could be conflicting. Bluetooth communicates on a 2.4 ghz band. Wireless Network runs on the following: 2.4, 3.6 and 5 GHz frequency
Try removing the device from you phone, and re-connecting it.
Apr 12, 2008 | Motorola Mobility H700 Wireless Headset
FIRST YOU MUST DETERMINE IF THERE IS STATIC ON YOUR PHONE LINE. EVEN WITH DSL THERE CAN BE STATIC EVEN IF THE INTERNET IS WORKING. IF YOU HAVE A CORDED PHONE TAKE IT OUT TO THE PHONE INTERFACE BOX AND OPEN THE BOX / THERE SHOULD BE A PLACE YOU CAN UNPLUG YOUR WIRING FROM THE PHONE COMPANY. PLUG YOUR PHONE INTO WHERE YOU UNPLUGGED THE WIRING AND SEE IF YOU HAVE STATIC THERE. IF YOU STILL HEAR STATIC IT IS THE PHONE COMPANY'S PROBLEM.
SOMETIMES UNPLUGGING FROM BOTH THE PHONE LINE AND THE POWER SOURCE AND REMOVING THE BATTERIES WILL CORRECT SOME PROBLEMS. FOR SECOND PHONES ON A SYSTEM THEY MUST BE REGISTERED TO THE BASE. ONCE IT IS REGISTERED IT SHOULD SHOW A NUMBER IN CORNER OF SCREEN (2)
THE MANUAL SHOULD TELL YOU HOW TO REGISTER SETS. IF YOU HAVE LOST YOUR MANUAL SEE IF YOU CAN DOWNLOAD ONE FROM THE WEB SITE OR CALL VTECH 1-800-595-9511
Dec 05, 2007 | Vtech 5.8GHz Analog Cordless Phone
Lands Phones Logo
114 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
