Question about Radio Communications
Program cable for Uniden IMH4100D radio
I need help with the wiring diagram for the program cable for
a Uniden Model IMH4100D radio.
I believe it is the same for a lot of Uniden mobile radios.
It is a 12 pin molex type cable.
thanks for any help
jbsims@netzero.com
N4JDP
  • RadioHQ Dec 23, 2008
    Me too.
I know it's been a while since you posted this question, but, the solution is simple. It does not use the 12pin molex on the back. The programmer connects to the micrphone port on the front.
You can get a schematic diagram to build a programming interface at www.cato2000.com/amx501 or do a search for amx501 on google. Parts cost me $23 at Fistell's in Denver plus another $13 for a board, box and a couple parts for a slight modification to the schematic.
You can also get programming cables on eBay for around $50.
Posted on Sep 23, 2009
Where can I get a Circuit Diagram for a Uniden UHF 012sx UHF CB Radio?
The only place you would get that is from Uniden themselves.
UHO12SX Manual - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH012.PDF
UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Features. 2. Preventative Maintenance. 2. Troubleshooting. 2. Controls/Connectors. 3. Missing: diagram ‎012sx
[PDF]UH8060NB - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH_8060NB_OM.pdf Operating the UHF CB Radio in Duplex Mode. 17. Scanning ... The Uniden UH8060NB is designed to provide you with years of trouble ... Built-in AVS Circuitry†.
[PDF]UHO12SX Manual.cdr - Uniden
https://www.uniden.com.au/RESOURCES.../uhO12SX_OM_2yrWarranty-Updated.pd... UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Controls/Connectors. 3. Indicators. 4. Included with your uh012sx. 5. Operation. UHF CB ...Missing: circuit ‎diagram ‎012sx
Circuit Diagram for Uniden UHF 012sx Google Search
Mar 19, 2017 | Uniden Radio Communications
I need a schematic diagram for a cb radio the radio is a electrophone model cb-550 PCB is a PTBM058COX with a SWR meter PCB PTSR007AOX need it to wire the SWR meter to the main board please help?
This circuit board is manufactured by Uniden, I believe. I was searching for it last week and found it by googling PTMN058COX Schematic. There are many brands using this board so don't worry about the brand name. Just download the file.
Oct 11, 2016 | Radio Communications
Wiring diagram for uniden pro 520 cb radio
is this the 520 or the 520 XL? go to www.cbtricks.com for the 520E wireing diagram
Sep 25, 2013 | Uniden Cb Radio Pro 520
I have a uniden cb pro 510 xl cb radio that the speaker doesn't work. I cannot find where or how the speaker connects into the power board. Is there a wiring diagram for this available?
Hi Anie,
START HERE: join yahoo group specific to your radio Make/Model, they have all the answers, plus you can download manuals and other stuff, i.e,. schematic diagrams for your radio.
I hope this helps.
Cheers,
Peter
Feb 12, 2012 | Uniden Radio Communications
MyCB radio wont broad cast
One of two things is wrong---either a problem in the radio or a problem with the Microphone----
Do you know how to open the mic plug and check the wires there?
Most of the time it is a problem with the mic cord---
Let me know if you need wiring diagram of the Mic--I can provide that---almost any 4 wire mic can be used to replace the stock one---
Original mic was 1 k impedance---but a 500 ohm mic will work and make the audio even louder.
Also have someone check the SWR or match on the antenna system--easy to do.
I am here to help---if this helped you rate this solution as I do this here for free.
SD TECH
Jan 01, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
How difficult is it to change freq in a sph21dt 2 way radio? Isn't it a simple plug in to a programmer?
You have to go to a Uniden dealer. They have the software, and the cables to reprogram the radio. You could buy the software and cables yourself if Uniden has them for sale. I bought 2 Yaesu FT-2800M's with the programming software and CAT cable (the software and cable cost $30) and found it a delightful and easy way to program the radios.
Longshorts.
Jul 17, 2009 | Uniden SPH21DT (1 Channel) 2-Way Radio
Need programing instructions
try this website here it has all uniden products http://www.uniden.com/index/manuals_results.cfm?cat=3 i believe it uses the same manual as BC248CLT
May 16, 2009 | Uniden BC340CRS Base Scanner
Need wireing diagram for a rci 2980 to tug8 mic
Here is what I have: If the Tug 8 is a 4 wire cable,1/shield 2/white 3/red 4/black 5/N/C 6/N/C
If the TUG 8 is 6 wire cable,1/shield & blue 2/white 3/red 4/black 5/N/C 6/N/C .The reason I gave two diagrams is I can never remember if the 8 or the 9 is 4 wire cable.Also if your radio keys up when you plug mic in reverse the black and red.Good Luck and take care!
Feb 24, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Need a schematic diagram on a uniden grant lt
http://www.cbtricks.com/radios/uniden/grant/graphics/grant_sch.pdf
Jan 29, 2009 | Uniden GRANTLT 40-Channels Base CB Radio
Mic wiring diagram
Want to wire cobra mic to a uniden washington radio
Nov 20, 2007 | Radio Shack TRC-447 CB Radio
Radio Communications Logo
643 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
