Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My estate washing machine is leaking
On the motor on the bottom of the agitator
  • 975 Answers
YOU need to replace the "CENTER SEAL" , looks like thats the problem , no need to remove MOTOR , just the inner tub inside the BIG tub , andyoull see the SEAL.
Posted on Nov 26, 2008
I am trying to replace the agitator dogs on a Whirlpool Estate washing machine. I haveremoved the agitator assembly and am trying to take it apart. How do you get the agitator assembly apart when it...
NOT SURE HOW URS WORKS BUT SOME DO NOT REMOVE FROM THE TOP OR MIDDLE BUT INSTEAD HAVE A COUPLER ASSEMBLY AT THE BOTTOM THAT REPLACES THE CAM DOGS FUNCTION SEE PICS
May 08, 2014 | Estate TAWS850PQ
Washer leaking water during wash cycle. Does not
There is a bad seal where the tub mounting with the transmission shaft to cause the leak. It leaks when it tuns. To access this, the agitation fin need to be out so you can see the big nut holding the tube in a place with the shaft. Below this nut is a seal or gasket to prevent the water getting out of the bottom tube. Replace this then you are good . Good luck.
Apr 21, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
MY ESTATE TAWS800JQ1 WASH MACHIN STOPED SPINING
The round rubber "belt" actually sounds like your motor coupling. This is a very inexpensive and straightforward repair job if this is the case.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking.
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Jul 22, 2009 | Washing Machines
Agitator on Estate washer will not fully agitate.
The dogs are broke on the agitator. Need a new set of dogs.......(duh ...not the barking kind, it's part of the agitator) Agitator has two pieces. It is the top piece.
Jul 14, 2009 | Estate ETW4400VQ Top Load Washer
Whirlpool washing machine agitator removal
my whirlpool washing machine's agitator bottom is working but the top is not. How can I fix this myself?
Thank you,
Ann
Nov 24, 2008 | Estate TAWX700JQ Top Load Washer
Not agitating
Check your drive coupler. Its the rubber piece between the motor and the transmission which makes the washer agitate and spin. the easiest way to check it is to lean the machine back and look for rubber on the floor. Then look behind the motor to see if it is still in tact. Next try wiggling it, If it wiggles a lot replace it. If that doesnt fix your problem, you probably have a bad transmission.
Nov 18, 2008 | Estate ETW4100SQ Top Load Washer
WASHER WILL NOT SPIN
This is probably a timer problem. In maytag washers the motor turns in one direction to wash, the opposite direction to spin. The timer decides which direction to start the motor.
Jul 05, 2008 | Estate TAWX700JQ Top Load Washer
Estate TAWS900JQ2 will not agitate or spin or drain
Most likely it is your top door safety switch, this switch is enguaged by a small plastic rod on the bottom of the top load door which goes thru a small hole on the top of the barrel shield, which inturn depresses a switch. Make sure that the switch is working propperly.
Dec 16, 2007 | Estate TAWS800JQ Top Load Washer
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
138 people viewed this question
Dan Webster
Dan Webster
Sal De
