Question about Compaq Computers & Internet
Sometimes my Compaq laptop computer screen gets all pink and pixley. It is like a magenta pink. It dosen't do it everytime just randomly but sometime I cannot get it to go away. Sometime when I would restart my computer it would return to normal but now it is not.
The issue is with the connection to the monitor from the motherboard. Since it is a laptop, it is harder to troubleshoot and fix. If you know anybody who is good with computers, have them remove the monitor and the shell around the motherboard. Then check and clean the connections from the motherboard to the monitor. Will probably be a ribbon looking cable. Also, try moving the monitor when it changes and see if it goes back.
Posted on Nov 26, 2008
  • 39 Answers
It sounds as if the culprit here is going to be either the screen itself, or the video card. On a desktop PC, this would be fairly simple to troubleshoot because you could switch out the monitor with one that is known to be working properly. If that did not solve the problem, you would next need to look at your video card. If the computer had onboard video, you could install an aftermarket video card and disable the onboard video.
Unfortunately, with a laptop it isn't quite that simple and you will more than likely have to take the unit to a professional repair service.
Graye
Compaq laptop, pink and green pixalted screen.
compaq day, endless posts... endless dead old PC's
who owns this old junk and why?
no LT stated, of the 1000s
no OS stated , XP?" what?
ever heard of photos, take a picture post it so folks can see reality?
all PCs break all do and often and LT vastly more often, its portable and that breaks them faster. x10.
what PC< we cant guess PC hear
LT ran at HP from 1984 to now. vast types, and compaq to.
simple tests.
1: ;runs ok with battery out , BINGO !!!! battery number 1 failure.
2: lent, lent packs vents overheats and CPu and GPU go NUTS.
all puters do this if not cleaned 1 time per year, all do. its called servicing the PC .
3: bad power pack of power is weak the electronics goes NUTS.
4: does the external VGA jack work to a external screen. yes/no.?
5: is this a 2008 Laptop with the GPU SOLDER BALL FAILURES?
next time post the PCs real model number.
or the service tag here is one random.
tag1-yurc2tkkgu0y15feq43cohvv-3-0_0.jpg this LT?
LOL 1984?
if I had any compaq relics' (most have a value of $20 or less)
id buy this.
see walmart see those great deals on pC that are good and supported?
be best,
http://pcdied.com/cheaper.html
Mar 19, 2017 | Compaq Computers & Internet
Compaq Presario v2000 freezes
If your laptop freezes randomly follow the steps given below:
  • Disable Unnecessary Services
  • Run Disk Checkup
  • Disable Startup Programs
  • Clean Registry Errors
You can also get more help from this article:
http://www.backspacetab.com/laptop-freezes-randomly-tips-to-fix-this-problem-for-good/
Dec 08, 2011 | HP Compaq Presario V2000 Notebook
In the center of screen is a kind of thick pink band and it turns green sometimes. i don't understand why its there or how it got there.how can i fix it? when i put my hand on the top of the computer and...
This needs to be taken care of by a computer technician, claim warranty support if you can!
Could just be a near severed connection at the hinges of the laptop screen or graphics card needs to be secured adjusted.
Further use may cause excessive damage!
damnor01
Jan 30, 2011 | Compaq Presario M2000 Notebook
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
Env2 screen help
how are you dleating your text messages from the outside
Mar 08, 2010 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Pink screen
It sounds like a bad inverter. A local service technician should be able to do it for under $100. Here the rate is about $70.
May 26, 2009 | HP Compaq Evo Notebook N610c
Compaq laptop pink screen sometimes
The normal cause of a pink tinted screen is that the LCD back light is beginning to fail. Kind of like a regular florescent bulb does when it starts to go bad. It may last for a while, but eventually you'll have to replace it.
Ron
Dec 13, 2008 | Computers & Internet
My Screen is pink
there must be some problem with the hardware of screen. get it checked from a professional
Jul 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Screen color becomes pink
Check for any EM interference near your Laptop (eg. Speakers, Cordless, TV, Music Systems, etc) and place your notebook away from them. The pink screen will go away in due course.
Mar 23, 2007 | Toshiba A70-S256 Notebook
Computers & Internet Logo
65 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
