Question about Samsung Refrigerators
My Samsung RS263022 fridge makes humming noises that comes and goes. One day it will hum, the next it won't. The time the noise varies. Listening to the humming, I can tell it is coming from the back. Where does this noise come from and how can I fix it?
    Problem Solver:
  • 11 Answers
The most common problem is the condenser fan, if it has one. It may need cleaning and or oil. Most of them do not have a place to be oiled. The fan can be replaced cheaply. Make sure the power cord is unplugged before taking the cover off of the compressor and fan area.
Posted on Nov 26, 2008
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Loud humming noise from right front end of 99 blazer
the noise is coming from the wheel section, it's called air splash, humming varies with speed, main causes are wheel alignment due to loose ball joint, check if your tire erodes on one side, next check your disc brake for clogged air cooled vain and disc wearing
Feb 23, 2012 | 1999 Chevrolet Blazer
I have a samsung french door refrigerator that is only 20 months old and it just started making a very loud humming noise that is coming from the back/top of the fridge. It stops when you open the fridge...
Hi David,
There's a big chance that the evaporators fan touching ice and that's why you hear that noise, if you have an ice build up you gonna have to defrost the fridge and test components to see which one has failed.
Thanks
samedayappliancerepair.ca
Jul 07, 2017 | Samsung RFG237AAWP Bottom Freezer French...
I know my santa fe, and i started listening a horrible humming
what kind of noise? if rattling noise and noiser when you accelerate, either in idle position or while moving, then you need to overhaul. if high pitch sound and noiser when you accelerate, then check you bearing in timing belt mechanism
Aug 02, 2009 | 2004 Hyundai Santa Fe
I have a whistle or humming noise from the front of 05 Montana.
Put wide tape on different areas of the windshield edge as a test to see if the noise changes.Then you may know where the noise originates and can correct the noise.
Just by chance,it is a wind noise? and not a front wheel bearing going bad?which is common on these vehicles and can create a humming at different speeds.Next time when the hum shows up turn the steering wheel slightly left and right at road speed and if you can change the hum,it's 99% a wheel bearing.
Apr 02, 2017 | 2001 Pontiac Montana
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Noise & icing
sonds like thre is a problem with the defrost because you should not have that much ice on the coils. go ahead and do a manual derfost and make sure that the drain lne is clear and not frozen up. If it is oyu can use a turkey baster with hot water to thaw it until the watr flows easily out the tube in the unit. also how are you gaskets looking? are they starting to leak air into the freezer and the refrigerator/ at 18 years old those are a few of the things to look at. Hopte that htis solves yur problems and if not don't rate this and I can still come back and post answer or solutions for yu. After the final them rate if you would be so kind. Thanks for using FixYa.
Jun 04, 2008 | Samsung RS2630WW Side by Side Refrigerator
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
188 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
