Question about Panasonic TH-42PZ700U 42 in. Plasma Television
2" vertical line down a plasma screen
The line is not always there, it may come and go.  The tv is only 3 years old and for the price of this Hitachi, I hope the tv is going bad.  Is this a cable issue with the HDMI and Uverse connection?
  • 152 Answers
Hello, you may have to get your tv serviced soon. it is developing internal board trouble. the plasma screen is controlled in sections by different boards or they work together to produce a sustainable image. it helps to have a picture to see what section has the line then you can get an idea of what board or boards are fualty.
there are many resistors capacitors and diodes and all types of components that with time get hot or over heated and loose there resistence properties or voltage values they become weaker or higher depending where the fualt is. this cuases the boards to go bad.
a local plasma service tech can give you an over the phone ruff estimate for the repairs if you can describe the trouble then you can decided to get it restored. the price depends on what board or boards are developing circut fualts. its cheaper to get it fixed now that it is still functional at least you know most of the circuts are okay..
good luck hope this helps
Posted on Dec 13, 2008
Hitachi 50" hd TV displaying black lines on screen
Sounds like your YBL-Y Buffer lower board is going out. There are 3 boards here. The Y buffer upper which controls the top half of the display, The Y buffer lower controls the bottom half and the Y-SUS main control those two boards. They work in unison. Usually if one goes out you have to replace all. You can also get lucky and just repalce the YBL and all may be well. Now if they are vertical lines up and down the OSD-On screen display, then this is indicitive on dry solder joints on the D, G E, F boards. Hope this helps...
Jun 29, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Black vertical strip on Hitachi plasma
seems like a lose ground issue from the vertical scan board which usually causes this problem. A scan board repair or replacement should fix this intermittent problem.....take it too your local repair shop before this problems spreads and the tv totally shuts down....
Nov 03, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Vertical lines on LG 50PB2DR
You need to replace the control board
May 22, 2009 | LG 50PX1D 50 in. Plasma Television
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42EDT41 plasma model-1" black stripe on right side
This is an old post but maybe it will help others. You will have to take the back off of the TV. On the bottom you will see ribbon cables coming from the screen and connecting to 3 PC boards. Take the screws out that holds the cable down. Underneath you will see 4 resistors marked 100. All you have to do is re-solder the resistors and your vertical line will be gone. You need to be good at soldering or you could damage the ribbon. The only ones that you have to re-solder is the ones in line with the lines on the screen.
Jun 06, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Panasonic TH-42PZ700U 42 in. Plasma Television Logo
91 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
