Question about HP Color LaserJet 2600n Printer
Hp couler laserjet 2600n
Supply memary error on cyan
  • ramoniglesia Aug 13, 2008
    The intensity of the cyan color is very low in the test page the windows flag appears as very light orange, I bough a new cartridge and the same happens
    I try the printer to self calibrate but nothing
There is a chip on the cartridge that is bad or missing. If this an after market cartridge this a common error with the chips. You either need to return the cartridge or find someone that sells the chips fot the cartridge.
Posted on Aug 11, 2007
  • jbuck Aug 11, 2007
    There is a chip on the cartridge that is bad or missing. If this an after market cartridge this a common error with the chips. You either need to return the cartridge or find someone that sells the chips for the cartridge.
Can you clean the ETB on the hp 2600n laser printer
yes you can clean it..you can use 40% solution alcohol
May 27, 2012 | HP Color LaserJet 2600n Printer
Impresion normal pero con bandas del toner azul impresora hp color laserjet 2600n . como las elimino ?
The cyan cartridge is leaking, replace it.
ell cartucho cian tiene una fuga, reemplacelo :-)
Nov 20, 2010 | HP Color LaserJet 2600n Printer
Our HP Color LaserJet printer has a 10.10000 error
10.000x Supply error E-label cannot be read or print cartridge is
not properly installed.
10.0001 = Cyan print cartridge
try this:
1 Reinstall print cartridge.
2 Turn on the printer.
3 If the problem is not solved, replace the cartridge.
Nov 03, 2010 | HP Color LaserJet 2600n Printer
Error no is 51.22
go to this link, and read page 12 .. your error is listed as
http://www.partshere.com/Models/Q6455A/CLJ_2600nTroubleshooting.pdf
51.20 Error
51.21 Error
51.22 Error
51.23 Error
The device has experienced an internal
hardware error.
51.20 Error-black scanner error
51.21 Error-cyan scanner error
51.22 Error-magenta scanner error
51.23 Error-yellow scanner error
Turn off the power by using the power
switch, wait at least 30 seconds, and then
turn on the power and wait for the device to
initialize.
If a surge protector is being used, remove
it. Plug the device directly into the wall
socket. Use the power switch to turn the
device on.
Laser scanners are not replaceable.
Replace the engine
please post positive feedback for me
Oct 17, 2010 | HP Color LaserJet 2600n Printer
My Printer HP 1600 Laserjet error 10.1001
Did you fix your problem? I have the same one. With Hp 2600N
All cartridge are new, and i removed the orange tab from each one.
I even tryed a second new cyan.
Did you remove All the orange tab from cartridge?
Feb 03, 2010 | HP LaserJet 1600 Printer
Hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
51.22 is a Magenta laser scanner error.
Try removing the magenta restarting the printer and reinstalling.
If that does not work you likely need a laser assm.
You might want to call a tech. to replace.
Apr 01, 2009 | HP Color LaserJet 2600n Printer
My Hp LaserJet 2600n stop black stop printig
the problem is cyan and yellow toner are low, u will change the cyan and yellow it will be cleared otherwise the will be empty u can't print any thing suppose one will empty other cartridge will not work
Aug 26, 2008 | HP Color LaserJet 2600n Printer
HP color jet 2840 cartridge not recognize
Turn the printer off and turn it back on again and see if happens now.
Jul 12, 2008 | HP Color LaserJet 2600n Printer
PROBLEM WITH PRINTER
"10.001" is probably 10.00.01 and is referring to a supplies error with the cyan toner. Try reseating the toner cartridge as the cartridge mounted chip may not have made good contact with the printer. If this doesn't take care of it, replace the cartridge.
Hope this helps!
Mar 07, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
395 people viewed this question
Clive
Clive
