Question about RCA F27242GY 27" TV
Cannot tune to channel 0 to use my dvd
I cannot add 0 to the channel list to use the dvd. Any suggestions?
    Scholar:
  • 72 Answers
If television has rca outs in the back(yellow, red, and white connectors) you must use the remote on the television to change the video input mode. If you do not have the RCA's you need to go to Radio Shack or Wal Mart and by an RF Modulator. and follow the instuctions with the modulator.
Posted on Jan 06, 2007
I re-tuned my TV (Samsung) on 03/09/14 as suggested by the pop-up message. i have now lost channels that are not listed as changing - namely Channel 24 (ITV4) and all the HD channels. i have tried the
You need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 07, 2014 | Samsung Televison & Video
I need to tune my sharp tv to a set top box but am not having any luck. It only has an antennae connection and no AV channel. I have done an auto tune but cant get the set top box to work.
I have no idea what an antennae connection is. I assume you are talking about a Coaxial cable converter (large box that connects in line on the cable input). If this is the case, the box is override either channel 3 or 4. It either has a switch to pick which one of these to use or it is written on the box which one it uses.
If you are using a VGA connection (3 pins with 1 yellow, 1 white, and 1 red connector), then you have to find the AV channel. Every TV has one, unless it is like 4 decades old. If the TV is a few decades old, it may not have a channel called "AV" or "AUX". For example my dad's 25 year old TV uses 91 as the AUX channel. It is common for channels in the 90's to be used for this or channel 0. Best to just turn all the manually add/remove channels while the box is on. Then you can spot the right channel and add it to the listings.
May 09, 2011 | Televison & Video
How to play raido
hi,
u didn't mentioned the model number of ur Coy DVD, any way do the following
first of all connect the AM and FM antenna to ur dvd player. ( located in the back side)
take the remote and do the following
1 .press the AM/ FM button. make selection u need AM or FM ( if u want to turn channels on AM select AM and got next step, after that select FM and do the same for turning FM channels)
2. press the MO /ST button to select stereo.
3. press the AUTO button to auto tune channels available
4.what till all channels memorized
now ur radio is tuned. u can directly select the station using the numeric keys ( for eg:- to go to channel 2, u should press 0 and then 2, if u want o go to channel 14, press 1 and then 4.
u can also select channels by pressing the RADIO plus and minus button .
when u want to listen radio press AM/ FM button and select ur desired channel.
ok
Dec 17, 2010 | Coby 5.1 Channel DVD Player with Home...
Every time the machine is switshed on it indicates that a new DVB service has been found. This suggests it is not storing this info when it does receive it - any suggestions?
Unles you add the new channel(s) each time, it will flash the message. Go into the tuning menu and either add new channels or retune completly.
Mar 21, 2010 | Televison & Video
I don't have a problem I have a question. I have a rotor antenna. I am in between NYC and Phila. If I autotune in NYC and want to turn my rotor for Phila will this tv allow adding of channels without...
Most sets with digital tuners do this. The best thing to do is manually save them into memory, unless they are the same numbers, this would keep the channels tuned until you go back to them
Nov 06, 2009 | Sylvania LD-320SS8 32 in. LCD TV/DVD Combo
Don't have a manual. i want to tune in the Fm radio. also how do you add video/movies to it.
to tune the radio you hit the play/pause button and scroll thru the channels with the toggle switch deally then to set the channel hold the play/pause button and it will bring up a list thing and you set it as a channel. to add videos ect. you have to do it thru your computer.
Apr 17, 2009 | Creative Labs ZEN V Plus MP3 Player
LG VCR GC480W can't tune in to tv
Any vcr I know of usually is tuned through channels 3 or 4 unless they are hooked up directly by RCA patchcord. 3 pronged- 2 audio and 1 video. With the patchcord you'll be tuning through an auxilary input in the tv.
Jan 27, 2009 | LG XBR446 DVD Recorder/VCR
Polaroid DVD player does not work
Check that the TV is tuned on the DVD channel, on some set is channel 0, or av , or ext etc.
If tv is tuned on the right cannnel, check that cables are fine, and check that you have connected the cable in the right way.
Aug 26, 2008 | Electronics - Others
Recording digital channels
Connect your set top box to Scart L2 (the Right hand one).
Select Prog 1. Then Channel down until you get to L2.
This should work.
Jul 12, 2008 | JVC DRM10 DVD Recorder
Tv problems
I am assuming that you are using cable and not an aerial/antenna.
On your concern "...channels do not tune...correct channel numbers...", it is possible that when you re-tuned the TV your setting was set to AIR or STD, try to re-tune again but this time pls verify that you are in CABLE mode. If on the other hand you are using aerial/antenna, then it is the other way around.
Channel 0 would automatically be your Audio/Video (which is where your DVD/VCR is connected). If you re-tune, chances are that Channel 0 ) would be back. To be on the safe side, pls power on likewise the DVD/VCR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Mar 04, 2008 | Konka K1938U 19" TV
RCA F27242GY 27" TV Logo
64 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
