Question about Kenmore Dryers
Gas Dryer is no longer generating heat. Air is moving, drum spins
It worked yesterday and the day before.
    Problem Solver:
  • 11 Answers
The most common problem I have found with gas dryers is the heat sensor which shuts off the burner when it senses too much heat. Check the sensor with an ohm meter. If your not an electrician I suggest you contact a service person.
Posted on Nov 26, 2008
How do I run a diagnostic? The dryer just quit heating. Everything else is working fine. How do I trouble shoot to see which part needs replaced?
If there is no heat, you can conclude the heating element has failed or a controller has failed but your description does not identify the dryer brand and indicate whether it is electric or gas.
Dec 26, 2014 | Dryers
No heat from dryer
If a Gas dryer look first to see if igniter is coming on or if drum where clothes are gets hot or not.
Dec 10, 2012 | Dryers
Dryer is not heating, timer does not move, drum spins, all air flow is clear
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Whirlpool LGR8648PQ Gas Dryer WHITE on...
I have just bought an Indesit tumble dryer model no IDC75, the dryer is working ie the drum is moving but there is no heat being generated from the machine
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Indesit Dryers
My dryer will not heat.....the drum spins and air appears to be blowing but not heating up to dry clothes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer spins and drum turns, but only cold air c...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
I have LG DLE2101W just installed yesterday. It
I found your manual and learned yours is a GAS dryer... the FIRST check is to be SURE the gas valve to your dryer is OPEN.
There is a Troubleshooting section, but NOTHING about no heat?
Know that LOW gas pressure CAN be a issue too!
I did find this:
"If the dryer no longer heats then the heating element may have failed, but it is not the most common cause. The most common cause for a dryer to stop heating is a blown thermal fuse."
The SECOND Link will be VERY helpful...
More help?
Cause 1 Thermal Fuse
Cause 2 Gas Valve Solenoid
Cause 3 Igniter
LG DLE2101W Support Manuals Warranty More LG
LG Dryer Not Heating
Thermostat
IGNITER
Dec 24, 2017 | LG Dryers
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Gas dryer/ whirlpool
well your generating heat which is a good sign, either there is a blockage in your venting() most likely source of issue!) but you say ou replaced, i would then look to replacing the valve coils, 279834, about 20 bucks, easy to replace... its possible that they open the valve upon start up allowing heat, but after being on 20-30 min they overheat and no longer open not allowing heat to generate..
Apr 03, 2008 | Whirlpool LGV4634JQ Gas Dryer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
