Pent 111 880Mhz 64 Mb RAM PC won't boot. Just makes one long beep one after the other until turned off. Re-seated RAM, tried another video card and Known good RAM but no change.
The beep pattern is a beep code and is how the motherboard communicates errors during the early booting process otherwise known as the POST (Power On Self-Test). List restart the computer and listen for the pattern of short and long beeps. Soltek does not list the beep codes in their manual, instead they refer to Phoenix who manufacturers the AwardBIOS on your motherboard. There are only two POST beep codes; a single long beep followed by two short beeps (Video error) and anything else. Apparently anything else you hear *probably* refers to RAM problems.
Since you?ve already tested both one of the remaining options is to install a *POST* card (about $30 to $50), boot the PC and read the hexadecimal error code for a more detailed clue to what failed. If you ask around you might find someone who has one and may be willing to loan it to you.
Another option is to write off the motherboard since the cost of the test equipment it about 1/3 the cost of a new board.
Let us know if you have any other questions and please don?t forget to rate the posing.
Turned laptop on, beeped and said rtc battery flat. fitted a new one, reset current date and time,...
(More)
Turned laptop on, beeped and said rtc battery flat. fitted a new one, reset current date and time, laptop works fine, only thing is now the screen display is too big! I can't reach down to the start menu or taskbar unless I hook an external monitor up, that works fine, and displays correctly. Even the default acer start up and windows boot up screens are too large on the laptop. It's almost as if the laptop thinks it has a 14inch screen to fill up instead of a 12 inch one. it would appear that a setting in the memory of the motherboard was lost when the battery went flat. Where is the screen size information stored on the motherboard?. There are no user changeable screen settings in the bios menu. The laptop came with a rescue disk and a driver disk, but neither of those changed anything. I tried an updated graphics card driver too but that didn't change anything either. The laptop originally had win98se, but I fitted a new hard drive, 512 mb of memory, and did a fresh xp sp2 installation 2 years ago, using the drivers and files provided on the acer website, and up till now all has been good.
when i start my sony vaio, it stays on the intel , phoenix and vaio logo page,, i then have to hit...
(More)
when i start my sony vaio, it stays on the intel , phoenix and vaio logo page,, i then have to hit esc to start,, how can i solve this issue
