Question about Kenmore 70172 Gas Commercial Dryer
Heating on series 70 Kenmore Gas Dryer
I look through the peep hole on the front and the pilot lights but does not stay on for very long. It will glow but the flame does not come on after the first time.
  • weasel337 Jan 27, 2009
    the heat comes on at least two times but dosn't seem to get hot enofh to dry things less then 5 hours
    Genius:
  • 1,028 Answers
Suspect the 2 black coils on gas valve/burner after first heat cycle they will open and not work until cool down
Posted on Nov 26, 2008
The dryer won't light 70 series Kenmore (gas)
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 08, 2010 | Kenmore 700 6972 Dryer
Gas dryer not heating up
it probably has a igniter, not a pilot light that lil hole is a check sight hole, close the door and set the drier to start , within a few seconds you should see a glow plug light up, if not,, check the main fuse in the back of the machine,, this is normally caused by a lack of flow for the drier vent and over heating
Aug 02, 2010 | Kenmore 63942 Dryer
Kenmore propane dryer 70 series does not lite
Assuming the gas is on. The most likely problem is a bad ignitor. Remove the bottom front panel(pop 2 clips at the top of lower panel with a flat screwdriver) and turn the dryer on Look for the ignitor to glow. If the ignitor does not glow test leads to ignitor for power if you have power replace it. If the ignitor glows then you are not getting gas check to make sure the gas supply is on.
I hope this helps if you need further assistance please let me know.
Apr 14, 2010 | Kenmore Dryers
My Kenmore 60 series gas dryer will not heat up. I checked the lint trap and it is clean. How do I open the front panel to check the pilot light?
Some dryers have a small inspection hole covered by a small platic cap.
Remove cap and look inside unit for pilot. Newer dryers have an igniter that glows when the dryer is turned on. It ignites the gas then goes out.
Jul 30, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 gas dryer no heat
your thermostat controls the heating
Jun 11, 2009 | Kenmore 62802 Electric Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
No heat to dryer
it mean it dont have a gas pilot and it has a ignitor instead ,,,, if you turn on the dryer and dont see a glow then it may have a bad ignitor ,,, on a kenmore it should not have a door to open unless it is a old unit and the newer ones has a peep hole to see into.
Dec 04, 2008 | Kenmore 72602 Gas Dryer
How to light the pilot light on a Kenmore gas dryer.
no pilot light has glow bar ignition ..ck to see if bar glows when start button is pressed should be small plastic cap on bottom of dryer front remove it to ckd for glow and burner operation
Aug 29, 2008 | Kenmore 75962 Gas Dryer
Kenmore 70 Series
Unless the dryer is extremely old, you do not have a standing pilot. It uses and ignitor or glow coil which could be your problem. It could also be defective gas valve coils or an open thermal fuse. Since it is a gas unit, I recommend you call a technician.
May 09, 2008 | Dryers
Kenmore 70172 Gas Commercial Dryer Logo
208 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
