Question about Magic Sing Along Consumer Microphone
Keypads wont work
When I turn on the mic the keypads wont work. what do i do?
You can do it your self take it down and clean it with alcohol the pads are dirty if that does not work the pads needs to be replaced contact contact dalbani miami florida for replacement.
Posted on Jan 27, 2007
Beaches wont turn mic
I for 1 don't know. But try to go to www.Turtle Beach.com they can help you out. I have Turtle Beach Ear Force XC1 and my mic I can talk but I can't hear anything but if your mic isn't working properly try using a different controller. If that doesn't help try getting a brand new mic.
Jun 23, 2013 | Turtle Beach Ear Force X42 Headset
When I press CALL key it dials 4 and when I delete RED(call cancel key) it dails 6!! And when I call someone or someone call me i hears his voice but he don,t!!
There are two problems in your phone, First one is your keypad and the second one is Microphone.So for keypad you need to change the keypad IC (filter) and fir mic you have to change the Mic/Mic IC.Therefore my comment is to contact mobile repairing shop.Good luck
Aug 30, 2011 | Nokia 3110 Cellular Phone
I can hear callers but they cant hear me
Hi sounds like your mic has stopped working its quite an easy repair you can get a mic from ebay, on the bottom of your phone under the keypad, the keypad clips out theres two screws undo them and slide the plastic piece off, your mic is the part with the two gold bits on pull it out with a pin remembering what way it goes in then put your new one in and put it back together.
Dec 21, 2010 | Nokia N95 Cellular Phone
When some one calls me he cant hear me but i can hear him..what is the solution?
Sounds like a mic problem.These units have mics that has two brushes that slide on contacts.Opening it by changing covers or keypads could disturb the connections or disorient it making it loose its contact.Solution to this is by openning the unit and locating the mic,usually found below the keypads.If you are familiar in the disassembly of the cover and keypads you can locate the mic which is either covered with rubber and the mic has an obvious form(round) and you can see on it the two brushes,see if that is making a contact on the circuit boards contact points.If it is the mic should be replaced.
Nov 25, 2010 | Nokia 3310 Cellular Phone
Mic to PC
This mic is a condenser type microphone. It needs phantom power (48v) to operate. Might want to buy a USB mic preamplifier box, like an M-Audio product, which will provide phantom power, xlr/1/4 inch inputs and USB output.
May 23, 2010 | Behringer C-3 Professional Microphone
L7 keypad light, mic not working... please
at first ribon change and then mic pice or light ic chake
Oct 28, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Dell LAtitude D600 mic wont work
right click on volume in right hand toolbar and open volume control then click options and then properties tick all boxes scroll along to mic and turn slider up should fix.
May 08, 2009 | Dell Latitude D600 Notebook
I have a motorola v262 and just changed the keypad, but i can hear callers and they cannot hear me? can you help?
graydog,
if you manage to change the keypad most probably the condenser MIC inside the phone been misaligned. try to check if the condeser MIC is properly sitted on it's original place and if you do have a multi tester you might as well check the resistance of the condenser MIC.
the nromal resistance for condeser MIC is 500ohms and some are 60 omhs.
cheers
mark
Jan 17, 2009 | Motorola Mobility V262
Wiring a mic
The Delta Force and Omega Force are wired the same way, so if the mic is not working on the radio, check the mic out to make sure it's working. Make sure you have the mic gain turned up on the radio. I assume the mic was not wired for another style of radio??
Dec 23, 2007 | Magnum OmegaForce S45 CB Radio
Magic Sing Along Consumer Microphone Logo
Top Magic Audio Players & Recorders Experts
Evan Benson
Evan Benson
Jojo
tornacious
Level 1 Expert
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
