Question about Magic Star Karaoke Microphone
Problems ok so when i turn on my magic mic there's sound but the key pad doesnt work.
0 characters
1 Points
My magic sing microphone stopped working how do i fix it
my magicsing doesnt switch on, neither with batteries nor with a given power supply
Dec 29, 2009 | Magic (ED8000) Professional Microphone
Magic (karaoke) mic sound delay problem when connected to HDTV
Ok..I found a workable solution. Essentially using my HDTV only for the lyrics(video output) and using a RCA to stereo mini plug cable to send the sound output to my amplifier that has a analog stereo input. Works like magic. No delay. It went from being unusable to WOW!
Jun 14, 2008 | Magic Sing Along Consumer Microphone
No Sound Coming out my Microphone
i know this might sound a little obvious and maybe irrelevant to the problem, but did you press the switch on the mic? it will turn the mic on and off. make sure sound and mic are unmuted in windows volume control. if both are these didnt solve the problem, test the mic on another computer. if the mic works, maybe its not the mic that has the problem. if the mic doesnt work, then your mic may be defective or damaged in some way or other.
Mar 28, 2008 | Philips PH62080 Uni-Directional Microphone...
Broken karaoke mic ed8000 model
Hi im joe,
if the screen says no font, no picture, no song data it means all the data installed was lost. you have to send it to the nearest service center to have it reprogram.
Feb 24, 2008 | Magic Sing Along Consumer Microphone
No sound comes out of the mic....
there's not really any way to tell whats wrong with it apart from it seems to be damaged internally.. if you have the receipt and its still under warranty i'd take it back and not mention the drop!
Jay.D Bsc Music Technology
Dec 16, 2007 | Magic (ED8000) Professional Microphone
Keypads wont work
you can do it your self take it down and clean it with alcohol the pads are dirty if that does not work the pads needs to be replaced contact contact dalbani miami florida for replacement.
Jan 21, 2007 | Magic Sing Along Consumer Microphone
Vocal problem
hi there..if there is video and background audio coming out from the TV, and no voice recognition from the mic- then mic is the problem. I believed the problem is the "voice coil". This is a part that can be replaced- you can contact me and we can repair that.
two ways to check
remove the mic ball
the part which the mic ball is is covering is the voice coil.
try holding both terminals (black and white wire)- if there is feedback sound- it is open and need to be replaced
try using your tester- test the impedance- there should be 500- 600 ohms reading
( or customerservice
Dec 18, 2006 | Magic Sing Along Consumer Microphone
Magic Star Karaoke Microphone Logo
13 people viewed this question
Top Magic Microphones Experts
Barbat Nae
Barbat Nae
T-Comtech Repairs
T-Comtech Repairs
Are you a Magic Microphone Expert? Answer questions, earn points and help others
